0-30V Stabilized Power Supply
Status
Not open for further replies.
lighty
Aug 9, 2010
38
Hi All
I'm wanting to build one of these supplies too, but neither of the 2 opamps are availible here in SA.
My transformer is rated 25V @ 5A AC, therefore open rectified voltage will be 35.4V, what other Opamps are recommended that I could use?
Thanks in advance!
audioguru2
Apr 6, 2004
12,026
The MC34071 is made by Motorola/ON Semi/Freescale Semi which is one of the largest semiconductor manufacturers in the world.
The TLE2141 is made by Texas Instruments which is also one of the largest semiconductor manufacturers in the world.
These opamps were chosen because their max allowed total supply is 44V and their inputs work without a negative supply voltage, and their outputs go much lower than ordinary opamps.
I don't know which opamps are available in South Africa. I don't know Oriental nor European opamps.
Thanks in advance!
lighty
Aug 9, 2010
38
Ok, RS Components can order the TLE2141 into the country for me, but its going to take just over a week for them to arrive :(
Serously, no one else can supply. :eek:
lu2dlt
Aug 11, 2010
Hello, I'm new to the forum I'm from Argentina I want to assemble the source query and I have the following problem I can not offset lower intentions to 0 volts replace all integrated and I still have the same problem thanks for your help
audioguru2
Apr 6, 2004
12,026
Hi lu2dlt. Your English is not clear.
What is "source query"?
What is "offset lower intentions to 0 volts"?
You did not say if you made the original project that has many problems including errors with its offset voltage adjustment. Or maybe you made the latest circuit that has no problems.
bean1028
Jan 30, 2010
7
Hey guys, first off my son spilled something on my laptop and my keyboard hates me now so I apologize if my grammar/puncuation/spelling is crap, I will do my best. I have just about finished the PCB, I used two thin single PCB's and made a dspcb, and since I am using a dremel to do everything and precision is nearly impossible, I am unable to join the top layer to the bottom layer so I simply held the components off the top enough to solder the top and bottom layers. I knew that some things were missing on the birdy file, butI figured that is the board audioguru and redwire made so I made mine identical to the birdy file, but now that I am in the process of attaching the external components, I have noticed that the voltage fine adjust pot is nowhere to be found on the schematic, and I remember reading that it was an afterthought but 0 results turned up when searching the forum for voltage fine adjust. Is it simply ran series with the 10k coarse? If so, can I also use this method for a fine current adj since I am building the 5A? Also, with the birdy file there is a note to hit ratsnet to fill a groud plane under d7 which was eliminated. Since I have absolutely no idea what that is supposed to mean, I just used a wire in its place, is that the same as what redwire was saying? Also, I have read through this forum so many times that the I get the specifics confused so if you know of any mods off the top of your head that I need to do before applying power I would really appreciate the info. The updated design has not been modified at all on my project, from the board to parts list so I only need the mods to make the original ps-6 desing work properly. This is turning out a lot smoother than expected, the biggest delay I have had was my wife took the assembled pcb and tossed in in a pile of other stuff and I had to completely strip it and make a new one because some components were ripped off and took thecopper with them... Not exactly the setback I anticipated, but if it were too easy I guess it wouldn't be as much fun.
audioguru2
Apr 6, 2004
12,026
I have never seen fine and coarse controls on a power supply. Usually they use a big knob so it can be fine and coarse.
audioguru2
Apr 6, 2004
12,026
bean1028 said:
Why does the parts list show a 1k pot for fine voltage adj?
Whose parts list? I think Redwire added a fine voltage adj. pot.
The original version and my versions never had a fine voltage adj. pot.
mendimano1
Dec 31, 2008
59
Hi i have just finished the 5 Amps version of the power supply , and it looks like work OK, i have loaded the P.S with 40 parallel connected bulbs ( 26 volts 100mA) and the voltage drop is only 0.1 volt when the current limiter is not on an the voltage drop is 0.5 volts when the current limiter is on, the R7 gets  hot with this load ( 2 parallel 7 watt 0.56 Ohm resistors), output transistors (3x MJ11016) are a Little bit warm, as far as voltage i have problem to bring it to 0 when potentiometer is at 0,  i get 1.1 volts i have electrolyte capacitor for C7 I'm thinking to change it to film type when I'm adjusting the RV2 so that at output i could have 30 volts I'm having 1.1 volt when I'm bringing the potentiometer to 0 and when I'm bringing down the RV2 voltage drops from 1.1 volts to 0.8 volts at the output with potentiometer bring down to 0, but then at the outup iw got 26 volts with the potentiometer put on maximum.
Guru how much should be the value of resistor that i should put at output so to bring the voltage to 0
audioguru2
Apr 6, 2004
12,026
R7 gets  hot with 4A load ( 2 parallel 7 watt 0.56 Ohm resistors)
Each resistor is dissipating only 2A squared x 0.56 ohms= 2.24W.
i have problem to bring output voltage to 0 when potentiometer is at 0,  i get 1.1 volts i have electrolyte capacitor for C7 I'm thinking to change it to film type
Yes because an electrolytic capacitor has "dielectric absorption".
RV2 is adjusted for an ouput voltage of 0.0V when the voltage pot P1 is set to zero. RV2 is supposed to adjust only about plus or minus 0.05V to cancel the amplified input offset voltage of U2. C7 will hold a voltage if there is no load.
Guru how much should be the value of resistor that i should put at output so to bring the voltage to 0?
Maybe a 3.3k 0.5W resistor should be added to the output to discharge C7.
mendimano1
Dec 31, 2008
59
So its OK to get hot?
is it OK to adjust with RV2 to have 30 volts at the output without no load?
audioguru2
Apr 6, 2004
12,026
So its OK for the power resistor to get hot?
The 7W power resistor is made to dissipate heat. it is made of substances that are fine when very hot. 2.24W is not near the 7W max rating so it is fine.  A power resistor operating at its max power rating will be extremely hot and will char the pcb, burn you if you touch it and melt plastic.
Yes. When the voltage adjust pot is set to maximum then RV2 in Redwire's schematic adjusts the output to be exactly 30.0V.
quote]"Maybe a 3.3k 0.5W resistor should be added to the output to discharge C7."
Connect it in parallel with C7??
mendimano1
Dec 31, 2008
59
I have replaced C7 from electrolit type to film capacitor ( see attached datasheet) and conect the two paralel 6.8 Kohm resistors
to discharge the C7, but still cant bring down the output to 0 still reading 1.1 volts when voltage potentiometer is set to 0 .
v735p.pdf
  • v735p.pdf
audioguru2
Apr 6, 2004
12,026
Which opamp do you have for U2?
In the latest circuit the opamp must be an MC34071 or TLE2141 which have inputs that work at 0V and have outputs that go down to 0V. Ordinary opamps will not work at 0V.
audioguru2
Apr 6, 2004
12,026
The circuit works perfectly with TLE2141 opamps.
Since your minimum output voltage is 1.1V then maybe your voltage-setting pot goes down to only 1.1V/3= 0.358V (the output amplifier has a gain of  3.074).
mendimano1
Dec 31, 2008
59
Dear Guru, i have tested and tested the power supply (5 amps version) and everything works perfect, i can bring down to 0 output voltage only when im bringing down to 0 the current potentiometer ( current limitng LED is on), is it OK?
audioguru2
Apr 6, 2004
12,026
Your power supply project has a fault. The voltage is supposed to be adjusted down to 0.0V.
Since the current regulation causes the voltage to correctly go down to 0.0V then since it reduces the voltage from the voltage-setting pot to 0.0V then your voltage-setting pot does not produce a low enough voltage when it is turned to zero.
mendimano1
Dec 31, 2008
59
So what do you sugest? to change the voltage regulating potentimeter? and should my voltage regulating potentimeter bring down the voltage to 0 no mater in what position is my current regulating potentimeter?
Status
