I have a Redwire schematic 5/04/2008 that is missing how the current-setting pot is connected.I have problems with my PSU (Redwire 5A version).
The voltage pot works good, but the current pot in the minimum setting, without load, lights the led.
Redwire's schematic and parts list have the correct parts and wiring for the input offset voltage null trimpot for the TLE2141 opamp U2.And the zero volt regulation trimpot don't adjust to zero.
Then the input offset voltage of your U3 opamp is worse than the maximum spec'd. A TLE2141 opamp has a max input offset voltage of only 1.4mV and an MC34071 opamp has a max input offset voltage of only 5mV. Replace U3.Hi AudioGuru,
R17 is 33 ohms and is connected at the lowest voltage pin of the current-setting pot. But I measure the voltages enter -C1 point (0V) and pin 3 of U3 (wiper connection in current POT): 8,3mV (current pot set to minimum and led on); 12mV (current pot set to led off).
Then maybe your U2 opamp also has its input offset voltage higher than the max in its spec. Replace it.When the led is off the output is 21,4mV (zero adjust trimpot set to minimum).
I can't remember which version you are making.For now I only have 6 OPA445 opamps... No more TLE2141
Yes.The film capacitor you are talking are polyester film type?
Yes.If I increase R17 value I will solve the led on problem in the current pot set to minimum?
I think your current meter is not calibrated correctly.And the current LCD meter shows less current than the multimeter shows when I power 1 120mm PC Fan 12V 0,33A (The multimeter shows constant 0,23A and the LCD meter shows 0,14A.
Yes.The R7 is two 0,47R 10W in paralel (0,235R = 0,24R?).
my latest version works only with MC34071 or TLE2141 opamps and will not work with 741 or OPA445 opamps.
I build the redwire 5A version with TLE2141 opamps.
Yes.
There are many plastic films. Mylar is another one.
I don't change the capacitor because I don't find a 10uF in polyester or mylar type.
Yes.
To the led go off in the current pot set to minimum and the voltage pot set to minimum or maximum I have to increase the R17 to 150R.
I calibrate the meter folow the instructions in the autor site. http://www.elfly.pl/multimetr/multimetr_en.htm
1) Try shorting R10.And the PSU don't reach zero volts... Can I make any modifications in R10 or in RV1 to make the 0V adjust reach zero?
The latest schematic and parts list has been posted many times. It works well, is reliable and parts for it are available nearly everywhere.panmil92 said:Hi. I want to make this psu, but i don't know which of all the designs to follow?? I have to take notice of Sam Carmel's modifications? Plz enlight me.
Have a look at page 30 for links to the newest designspanmil92 said:Hi. I want to make this psu, but i don't know which of all the designs to follow??
It looks like Sam Carmel made the original version that has many faults. His mod is not shown.For the mod check at the end of this page
