audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Tesseract's schematic does not show P1 or P2.The problem I am having is that I have no current control. If P1 is at max and I turn P2 to max, then both the voltage and current drops to zero, and vice versa. The LED never lights up. And the max current never gets above 0.9A.
On my schematic, P1 is the voltage control and P2 is thew current control. If P1 is at max and the voltage trimpot is calibrated then the output voltage is 30V (or less when the current is higher than the current control setting). Since your voltage and current drop to zero when P2 is at max then you probably have P2 wired backwards.
R7 senses the output current. U3 controls the output current and compares the voltage across R7 with the setting of P2 and reduces the output voltage so that the output current (and the current in R7) is the same as the setting of P2.
