@ audioguru, thanks for the input, you were right. It was the Q2. I put in a new one and now its working like it was before, but still not right.
I can:
Set voltage from zero to 11.1
Control current and also turn it off completely (led lights on)
Now some data:
- i used redwires pcb with latest values (see picture)
- power is supplied by 2x15 (series) 160VA transformer
- ac voltage is fine: 30v
- dc voltage after rectifier and supplied to 2n3055`s: 42v
- q3 is a bc327, collector:32v, emitter: zero aslong no c.c, base ~32v
- q2: zero to 11v on emitter (reacts on base voltage), 42v on collector, base zero to 11.9v
- negative rail is @ -1.3
- R1 is 2200 Ohm, R2 is 82 Ohm, both 2W, still getting extreme instant-fingerburn hot
- u1 pin7 voltage: 42v, pin6: constant 10.8
- p12: 0-10.9v, p10: zero constant, p5 10.9 constant
- p13:0-0.9v?, p11: zero constant, p6:0.9v
- u3: pin7: 32v, 6:zero to 32
- u2: pin7: 42v, 6: zero to 11.7
- trimmers seem to have no effect at all
It really seems that is dont get the voltage gain of 2.68 times. i start thinking about faulty opamps? they are hard soldered, so not fun to exchange them, but i wanted to put in sockets anyway ....
I hope you can provide some more help.
