picotrain said:
In the image of the populated PCB in the Rev 5 zip file from the updated 1st post in this thread, there appears to be a wirewound with heatsink resistor mounted on the TO-3 heatsink. Seeing as the 10W resistor is mounted on the PCB (and using a 0.27Ω instead of 0.47Ω with 5V6 Zener missing?), I can only assume that the resistor is the 0.33Ω on the emitter of each 2N3055.
Would that then mean the 2W rating (according to the parts list) of the 0.33Ω is a typo? 2W seems a bit (lot?) small.
The photo shows Redwire's 5A version of this project. The 0.27 ohm/10W resistor on the pcb is R7 which is 0.47 ohms/10W on the 3A version. 5A x 0.27 ohms= 1.35V. 3A x 0.47 ohms= 1.41V which is almost the same.
5A squared x 0.27 ohms= 6.75W. 3A squared x 0.47 ohms= 4.23W which would make a 5W resistor extremely hot so a 10W resistor is used.
The missing heatsink in the photo is for the bridge rectifier module in the upper left corner.
I do not know why the 5.6V zener diode is missing from the pcb in the photo.
With each of the two output transistors conducting 1.5A then each 0.33 ohm emitter resistor dissipates 1.5A squared x 0.33 ohms= 0.74W which would make a 1W resistor extremely hot so a 2W resistor is used. The 5A version uses three output transistors, each with a 0.33 ohm emitter resistor then each conducts 1.67A so again the resistor is 2W.
