0-30V Stabilized Power Supply
Status
Not open for further replies.
redwire
Nov 10, 2007
244
Canyoncruz said:
Have you guys seen this variation?
Something similar was discussed several pages back.    IC1A seems to be missing the connections on pins 4 and 7.  It lists older  OpAmps  Tl082 which has a maximum voltage rating of 36 which is where it must operate.  I think the components used for the 9.5 V reference voltage is overkill, but I support the concept.  This design uses a voltage regulator for the negative rail.  I prefer the simplicity of the dual diodes to create the negative reference voltage and the 10V zener to tame down the rail voltage for the op amps that Audioguru has suggested.    It may be a matter of preference.
redwire
Nov 10, 2007
244
Hi Twentysix,
By the way the only change I have made to the design is I added an NPN (BC546) transistor between the neg rail and pin 6 of U2 to eliminate any voltage at output after the PS is switched off and a 24v Zener at pin 7 of U1
what design did you use and what values did you use for R13 and R14?  The reason I ask is because if you use the latest design that has a negative rail of -1.2 V instead of -5.6V and you use the original values for R13 and R14 then the voltage to the base of  Q1 may be positive all the time instead of being slightly negative until shutdown.
Canyoncruz
I google translated it and I copied to word, too long to past here. Send me an email address and I will forward
Hero999
Oct 28, 2007
2,433
Can you please save it and attach the file in plain text or PDF format, as the forum software doesn't allow Word documents.
Canyoncruz
Hero,
I wasn't asking for help. I was pointing out there was another variation of the circuit and it is in Czech. The translated file is large. I guess anyone can go to the link and translate it themselves.
liquibyte
This is just basically a bog standard google or bing translation.  Canyoncruz sent me the .docx and I converted it to a pdf.  I had to resize a few of the images but I think it's ok for the most part.
Quick edit:  I did some better formatting and the pdf looks much better now.
czech_power_supply.pdf
  • czech_power_supply.pdf
EmbeddedCom
Hi All,
Ive decided to build this power supply. Where can I find the transformer ?
Thank you.
liquibyte
EmbeddedCom said:
Hi All,
Thank you.
I used this one.  $24.46 each isn't too bad considering the prices on transformers lately.  I know a lot of people tend to use toroids but I had a large case that wasn't doing anything so I went with traditional transformers.
V
VittoYi
Hi everyone!
I'm trying to build this power-suppy as well, however,  I'm doing it as a "low-cost" power supply, spending as less as I can.
Given that, I already have a 24V + 24V 300VA transformer (from an old project) which provides at top 6A for each output line.
Can I use this one to supply the circuit? Would the circuit current consumption get up to 6A or it can be limited to 3A ? ??? ???
Thank you, in advance.  :)
audioguru2
Apr 6, 2004
12,026
VittoYi said:
Hi everyone!
The improved and corrected circuit uses a 28VAC or 30VAC transformer. If you use half your transformer (24V) then the maximum output voltage from the project will be about 25VDC at 3A, not 30VDC.
The improved circuit has a trimpot to set the maximum output current at 3.0A.
V
VittoYi
Can you please send me the link of the new version? Because I could only find one where a 24VCC is required. Anyway, it still seems to consume 3A to me. So, the transformer I have would work fine with that.
I mean, the fact that the transformer can supply 6A doesn't mean that the circuit would consume 6A, right?
Thanks, and sorry for my questions, I'm still learning! ;D
audioguru2
Apr 6, 2004
12,026
I guess you found the original old project that has many errors. It cannot produce 30V at 3A and it is not reliable because many parts are overloaded.
The improved project can produce 30V at 3A and it is reliable.
I guess you did not learn the basics of simple electricity and Ohm's Law.
The battery in my car can supply 800A to the starter motor in winter when the cold oil is very thick. But the clock in the car does not use the entire 800A, instead it uses only the 0.002A that it was designed to use.
My home has electricity that has a maximum current of 200A. But my clock radio does not use the entire 200A, instead its clock uses 0.002A that it was designed to use.
The 0V-30V lab power supply consumes a little more than 3A from the transformer when its output supplies 3A DC because some of its parts use extra current to do their work.
Here are the improved schematic and parts list:  View attachment 42114
V
VittoYi
Okay, this sounds perfect.
Is there a PCB scheme avaliable?
About Ohm's law and stuff... well, let me say I did study those things, what I meant to say is that 6A as an input can burn the circuit if the output consumes more than 6A.
I was just worried I could not limit the current to 3A. (Now, I know this is possible thanks to the trimpot on the board)
Just one last thing, in the circuit you mentioned, is it possible to add a protection for short circuits?
Thank you, audioguru. I'm learning a lot with this project! ;D ;D
V
VittoYi
audioguru said:
Yes, there are a few pcb designs posted in one of these threads about it.
There are so many PCBs that I really can't find the one for the fifth version.
Yeah, I double checked the part and it has reversed legs, why I don't know.  I mirrored it and corrected the board file and gerbers to reflect the correct part I used.  I deleted the zip file from my previous post so I don't cause confusion and I'm attaching the corrected version here for anyone that wants to use the files.  Included are the schematic and board files plus the gerbers that I used at Itead to get the boards made.  The recommended weight should be 2oz copper for 3A given the trace width, however, that adds $25 to the cost of the boards with them.  I used 1oz and am going to run 22awg jumper wire along the bottom between the components and the outputs to handle the current.  Probably not the best solution but I imagine it will work alright.
Edited to include a parts list of Digikey part numbers.
Does the one from liquidbyte work fine? I don't really need a PCB, but since I want to get two of these circuits working together in the same box, a PCB will make it easier to fit in a standard eletronics box. I'd like to get the copper traces (if anyone designed them already) so that i can get the PCB through photoengraving.
liquibyte
I have two of mine in the same box running independently and they work just fine.  I have also loaded them to the full 3A @ 30V and have seen no issues to date other than the ones reported by Redwire about the voltage spikes on power on and off.  I don't have a DSO so I can't really investigate this too much but can see the spike with the Conar 255 I do have.
I've sent out four of my boards to two other members here (philtherepairman and cscott719) and they could probably give you an indication if they are working for them as expected and perhaps they'll post here as to how things are working out for them.  I have four boards left and would like to keep two more for myself but if you're interested PM me.
EmbeddedCom
redwire said:
A few weeks ago I changed the board by deleting U1 and associated components and replaced it with a 12V linear voltage regulator (PN  L78L12ACUTR).    I added two cap to keep the voltage regulator smooth.  Today the new PCB boards came in.    The only other board change was C7.  I switched to a film instead of electrolytic.  I ran the same tests on the scope and there was no ringing.  Based on that, I assume the ringing was U1 trying to stabilize when the power supply was removed but C1 still had a charge.
Can you please post your modified schematics ?
Status
