f's mean it's empty you're not using CSID.
it's a lock code so someone with Compass can't hack into client panel...it's
not visible in manual programming on the newer panels but it's there and
visible when you connect with Compass - it'll be all F's if you're not using
it.
Let's say you do a takeover and don't clear the csid with *96 then even you
cannot remotely connect with Compass because the old company may have been
using csid...but you got into programming on site because keypad programming
was NOT disabled. You'd have to go back out and manually clear the CSID,
then back to the office and use Compass to connect. (I've done this a couple
of times)
| D'Oh, I just realized I don't use the CSID either, what the hell is it
| anyways?
| all I see is a bunch of Fs
| | > on the first time.
| > after that I use Account Number selection - I don't use the CSID since
no
| > one could contact it without an account number and no one knows that but
| me.
| > Then I lock keypad programming. That should be good enough right?
| > | > > | > | > > > Nabob, vista15pcn, don't use a lot of them but last 3 I bought
| this
| > | > summer
| > | > > > do the same thing. I just do the workaround thing but maddening
| > | > > nonetheless.
| > | > > > I can pick a time with DSC and download just that. Compass is so
| > | > tedious,
| > | > > > I'm just not getting the hang of it, I keep forgeting to close
| > | > > communication
| > | > > > before trying to exit, I never remember which way to connect
that
| > | works
| > | > > > reliably, things like that, drives me nuts but I like the panels
| and
| > | the
| > | > > > wireless.
| > | > > Oh hell mikey thats the problem, you use the Canadian version of
the
| > 15P
| > | > > As far as the speed of the download it's only slow the first time
| you
| > | > upload
| > | > > it, after that its fairly fast
| > | > ahah, so I shouldn't be using the first time connect , cross fingers
| > | > checkbox every time I try to connect? Sometimes it just seems the
only
| > one
| > | > that works.
| > | The first time connect is used if you don't have a CSID programmed
into
| > the
| > | panel, if you did then you'd use the other selection
