help with IR2110 chips
Maglatron
Jul 12, 2023
2,025
so my meter isn't a needle in the centre its at the left side when I connect the probes and push a magnet toward a coil, am I looking for deflection to the right and whichever the positive probes wire it's on is the positive lead of the coil? just making sure my new coils have arrived waiting on the ferrite rods
Maglatron
Jul 12, 2023
2,025
mild steel welding rods have arrived now just got to make time to work on fitting the coils will take pics :)
Maglatron
Jul 12, 2023
2,025
ok so I have bought a new transformer( 5.75 : 1 ) how do I modify the the transformer in the ltspice sketch please?
  • NEARLY WORKING.asc
Maglatron
Jul 12, 2023
2,025
the inductor L3 no longer represents 15 watts also want to change the transformer to a 5.75 : 1 and I do not know how to modify it! thanks
  • NEARLY WORKING equal coils.asc
Alec_t
Jul 7, 2015
3,820
The L2 and L3 windings are short-circuited in your schematic.
The inductance of a transfomer winding varies as the square of the number of turns. So for a transformer with a 5.75:1 voltage ratio the inductance ratio of the windings will be 5.75^2:1 = 33.1:1.
Do you know the winding inductances of your transformer? If not, googling for properties of a similar size transformer may give some idea.
Bear in mind this is only a simulation, using fairly arbitrary values.
Maglatron
Jul 12, 2023
2,025
I bought a new 8 : 1 transformer because I got the wrong one the L3 represents the motor I will be running, it's a 15watt motor, someone helped me with it a while back, forgotten who! the new one I have bought is 30v to 230v! and is rated at 120watt the 15watt motor is an oven fan motor 230v 15watt
Maglatron
Jul 12, 2023
2,025
so I just rang the vigortronix company and the man Gordon answered the phone say's he'll ring back later!
Alec_t
Jul 7, 2015
3,820
Inductance ratio for a 1:8 voltage step up ratio will be 1:64.
Maglatron
Jul 12, 2023
2,025
how does this help not being sarcastic I can't see the relevence, thanks I recon it's got something to do with the spice program!
Alec_t
Jul 7, 2015
3,820
The inductance ratio in the Spice program will affect the output voltage in the simulation.
So how do I know how many henries the coil has?
You don't (if the tranny spec doesn't give it), but as I said in post #366, "googling for properties of a similar size transformer may give some idea".
Maglatron
Jul 12, 2023
2,025
do I need other parameters like resistance's of the primary and secondary anything else etc... also as I mentioned the L3 inductor represents 15watt motor but in thee sim now it draws alot more wattage, any ideas on that?
Alec_t
Jul 7, 2015
3,820
The more parameters you know and apply the closer the sim result to the real world. But guestimates should put you in the ball-park.
Maglatron
Jul 12, 2023
2,025
getting someone to email vigortronix for me the inductance primary and secondary, secondaries wound together in series (black and yellow tied together), resistance's of the primary and secondary max currents winding numbers on both primary and secondary and then the coupling factor!
Maglatron
Jul 12, 2023
2,025
so do you know how to model a 15watt motor in spice Mr Alec_t,? or anybody else for that matter! it's one of these type!
Alec_t
Jul 7, 2015
3,820
Judging by this article, accurate simulation of a shaded-pole motor would be tricky. I'd just use an inductor with appropriate inductance and resistance parameters.
Edit:
Try 1.3H, 50 Ohms. These give about 15W on a 230V rms 50Hz supply, but may be some way off realistic values.
