help with IR2110 chips
Maglatron
Jul 12, 2023
2,025
I actually think that it is counter intuitive to put the resistance of the coils into the internal resistance of the voltage sources, tell me your thoughs on this!
Maglatron
Jul 12, 2023
2,025
ok so I get 35watt average so I can't get around the resistances, they simply are what they are! and they come to around 50 - 60 ohm
Maglatron
Jul 12, 2023
2,025
so if I set the resistance values to 20 Ohm it's about acceptable but thats not true to real life
Alec_t
Jul 7, 2015
3,820
Sadly, that's the case, unless you can source bigger coils with lower resistance but a similar number of turns.
Driving a 15W load from a 30V supply needs 0.5A current, but 0.5A would drop 25V across a 50 Ohm coil resistance.
Maglatron
Jul 12, 2023
2,025
I'll fit the coils I have, in place, and then see what the most amount of voltage I can get on each of the four coils before the rectifier max speed never been to max speed yet!!! and take more readings!:)
Maglatron
Jul 12, 2023
2,025
why does the capbank charge to over 60volts if the voltage off of the coils is only 40volts?
Maglatron
Jul 12, 2023
2,025
and if the coils are producing 40volt why would it go down to 30volt?
Maglatron
Jul 12, 2023
2,025
and you're forgotten one thing, the 15watt load is driven by four coils that have 50ohm each! and each produce 40voltAC! so DCvoltage is what? and then there's the smoothing cap bank
Maglatron
Jul 12, 2023
2,025
so how would this play out if the, the 15watt load from a 30volt supply needs 0.5 amps, across the four coils that 0.125amps each coil, 50ohm * 0.125Amp, the drop across each coil would only be 6.25volts across the 50 ohm coil resistance!
Maglatron
Jul 12, 2023
2,025
could I wire the coils in parallel to quater the resistance? or wire the two coils that are on the back of the machine in parallel and the two coils on the front of the machine in parallel that would halve the resistance!
Maglatron
Jul 12, 2023
2,025
so I tried to put the coils that are the same phase in parallel and the result is better, not perfect but better, about 27volt. I take that back! nevermind
Alec_t
Jul 7, 2015
3,820
Because the circuit configuration uses both halves of the AC waveform and is in effect a voltage doubler.
The peak voltage is 40V, the RMS is less, and the coil resistance drops voltage.
I haven't forgotten. The coils aren't in parallel. The coil voltages are not in phase (they're in quadrature in the sim, but in the real world they would be time-separated according to the coil spacing around your machine).
Maglatron
Jul 12, 2023
2,025
so can this be replicated and implicated ( using both halves of the wave ) in LTspice
can I put the coils that are in phase ie the two at 0 degrees and then the two at 120 degrees this would halve the resistance, thanks
Maglatron
Jul 12, 2023
2,025
the ones at the back of the wheel are in black and the white lag by 120 degrees the wheel turns anticlockwise I hope you can understand the diagram, thanks! 1706907905261.png
Maglatron
Jul 12, 2023
2,025
the coils on the front are 12 O'clock and 9 O'clock the coils ont the back (still looking from the front) are 9 O'clock and 6 O'clock! thanks
Maglatron
Jul 12, 2023
2,025
I think this part is important to use both halves of the waveform any ideas
Maglatron
Jul 12, 2023
2,025
so I have a spare flywheel and just bought some new magnets going to try a different configuration next time and put the magnets all in phase so that I can parallel the coils but not giving up on this wheel just yet!
