help with IR2110 chips
Maglatron
Jul 12, 2023
2,025
ok so how do I find the inductance and resistance I mean I can just measure the resistance I just read you edit where did you aquire the 1.3H and the 50ohm
Judging by this article, accurate simulation of a shaded-pole motor would be tricky. I'd just use an inductor with appropriate inductance and resistance parameters.
Edit:
Try 1.3H, 50 Ohms
Maglatron
Jul 12, 2023
2,025
if I get the actual resistance can you determine the inductance through a relationship equation?
Maglatron
Jul 12, 2023
2,025
power consumption = 15watt
resistance of coil = 24ohm
frequency of the AC = 50Hz
current draw = 0.0652Amp
voltage = 230volt
can you find the inductance with these values?
if so can you tell me the steps to do it?? thanks
Maglatron
Jul 12, 2023
2,025
found this Use the formula L = R * sqrt(3) / (2 * pi * f) and if I substitute R for 24ohm and frequency 50 I get 0.132H, but that is not good for the sim to be honest!
Maglatron
Jul 12, 2023
2,025
voltage = 230volt
can you find the inductance of the motor with these values?
Maglatron
Jul 12, 2023
2,025
should be getting the results and figures of the tranny today too, with a bit of luck!
Maglatron
Jul 12, 2023
2,025
so the guy, gordon emailed back this is exactly what he wrote
model VTX-146-160-115
primary inductance = 9H (100Hz, 0.3v)
secondary inductance = 130mH (100Hz, 0.3v)
primary resistance = 12ohms
secondary resistance = 0.14ohms + 0.14ohms
interwinding capacitance = 443pF
can I use these numbers for 50Hz
  • NEARLY WORKING equal coils added new coil.asc
Maglatron
Jul 12, 2023
2,025
the blue line represents the power dissipation of the L3 coil (motor) with the parameters 1.3H and 50ohm red is the output of the tranny dark blue and green are the osccilations going into the tranny! the power consumtion by the motor is way above the 15watt that it should be!! thanks1706794255268.png
Alec_t
Jul 7, 2015
3,820
Trial and error in a sim, with the 'motor' driven by a 50Hz sine-wave.
Nope.
Nope. Lamination dimensions and permeability, plus the way the coil is wound (layers, size, wire gauge) all affect inductance.
Yes.
Maglatron
Jul 12, 2023
2,025
hey up Alec_t, ok so I put in the numbers and now I just need to model a motor for 15w could you give it another go please the wattage that it draws I don't even understand but it's not linear and I think it draws more than 15 watt1706821053775.png
Maglatron
Jul 12, 2023
2,025
so I'm running square wave not sine wave, is there an alternative figure that I can use for square wave please, thanks
also where do I put the interwinding capacitance value
and how on earth do you change the scale in the simulation window of current power and voltage respectivly
Maglatron
Jul 12, 2023
2,025
so the voltage drops to around 20volts from out put of rectifier into the main circuit in my schematic and I dont know how to keep it around 30volts!!!
  • NEARLY WORKING.asc
Maglatron
Jul 12, 2023
2,025
so this one works 1000x better not even sure what I have changed!!
  • newest.asc
Alec_t
Jul 7, 2015
3,820
You reduced the internal resistance of your voltage sources V1-V4 from 54 ohms to zero! All those Ohms were starving the rest of the circuit of current.
But now the modelled motor is dissipating about 65W.
Maglatron
Jul 12, 2023
2,025
alright so I wanted to put in the Ohms of the coils was I putting it in the right place in the program? also how do you change tha scale of the resistor amps and watts please? do I treat these voltage sources different to coils with magnets passing because they are different in some way? how do you get 65watts from this 1706888508183.png
