Is this circuit fit for purpose if used on a 12vdc pump?
cygnusv
Oct 7, 2014
79
Three years ago KrisBlueNZ - RIP - kindly produced the following circuit for use on my 24 volt boat. The problem was back emf destroying contacts in the pumps pressure switch. This circuit completely solved the problem and 3 years later it is still in continuous use.
2 friends of mine are suffering exactly the same problem, but with 12 volt pumps. These pumps are rated at not more than 6 amps. Would this same circuit work on 12 volts or should components be upgraded?
270677-schematic-16-png.15859
Many thanks, Stu
Alec_t
Jul 7, 2015
3,821
The diode is rated for 15A continuous, so should be fine, even allowing for pump switch-on surges.
duke37
Jan 9, 2011
5,364
One diode is NV-1S3210 and the other is NV-1N3210R so they are of opposite polarity. The symbol we see may not be an indication of polarity and it looks as if the lower picture is a mirror image.
Did Kris reverse the image to show the physical connections?
Cannonball
May 6, 2017
193
If there is any doubt, check it with your service meter before installing it. The marking on the diode is the same in both schematics and I believe that is correct.
The diode in the top schematic is installed wrong.
cygnusv
Oct 7, 2014
79
I think Kris simply reversed the image, because I used the top image with the threaded end of the diode to the negative side of the circuit. Three years on it still works properly and it is still the original pump.
Is everyone happy that this will work with 12 volts rather than the 24 volts it was originally used for?
