Altera Agilex 2X FPGA Feature PCIe 7.0 and Up to 1.211 TOPS AI Performance
Altera unveils Agilex 2X FPGAs with HyperFlex architecture, advanced AI acceleration, 256 Gbps transceivers, and next-generation connectivity for AI infrastructure and communications.
Altera Corp. announced a new family of FPGAs targeted at intelligent systems, including physical AI at the frontier and the digital AI infrastructure. The newly developed Altera Agilex 2X FPGA and system-on-chip (SoC) portfolio encompasses superior performance, mid-range, and power- and cost-optimized devices and is supported by a unified agentic AI design flow. The first officially announced FPGA and SoC family is the Agilex 27, focused on AI infrastructure, high-speed networking, 6G and satellite communications, and aerospace and defense applications. The family offers 14 device models that can be FPGA-only or FPGA SoC devices with incorporated Arm processors.
The Altera Agilex 2X FPGA product line includes four device family models: Agilex 27, Agilex 25, Agilex 23 and Agilex 22, each tailored for different power- and-cost performance, based on the application’s requirements. This lets customers scale different mixes of connectivity, bandwidth, capacity and power efficiency to meet requirements for a variety of applications from physical data centers to communications, aerospace and defense. Altera’s third-generation HyperFlex architecture powers the new Agilex 27 FPGA and SoC family, which the company claims offers 1.8x the performance per Watt versus the previous-generation Agilex 7 FPGAs. Other features include up to 17.6 million logic elements, second generation AI Tensor DSP blocks, Arm Cortex-A720/A520 processor subsystem in the SoC FPGA variants, 256 Gbps transceivers, PCIe 7.0, 1.6Tbps Ethernet, and LPDDR6 memory assistance.
Altera Agilex 27 FPGA and SoC
Altera Agilex 27 FPGA and SoC Family Specifications:
- FPGA Architecture:
- Third-generation HyperFlex architecture with enhanced Adaptive Logic Modules (ALMs)
- 866K to 17.6 million logic elements (LEs)
- 274,190 to 5,683,872 ALMs
- Up to 1.8× higher performance per watt compared to the previous-generation Agilex 7
- Processor: SoC Variants Only
- Armv9.2-based Hard Processor System (HPS)
- Dual-core Arm Cortex-A720 and dual-core Cortex-A520 processors
- CPU operating frequency up to 2.3 GHz
- 2MB shared L3 cache
- 512KB on-chip RAM with ECC support
- AI and DSP Acceleration:
- 1,096 to 21,048 second-generation AI Tensor DSP blocks
- Up to 1,211 TOPS INT8 computing performance
- Supports INT8/INT9/INT16/INT32, BFLOAT16, FP16/FP32, TF32, and complex arithmetic
- Multiple processing modes, including fixed-point, floating-point, tensor, and vector operations
- Memory:
- On-chip FPGA Memory:
- 40Mb to 822Mb M20K memory
- 63Mb to 1,096Mb M80K memory
- 8Mb to 158Mb MLAB distributed memory
- External Memory Support:
- DDR5, LPDDR4, LPDDR5/5X, and LPDDR6
- 3 to 18 hardened memory controllers with inline memory encryption (IME)
- Up to 9.84 Tbps external memory bandwidth
- Memory-in-package (MiP) options available on M-Series devices
- Storage and Multimedia Interfaces:
- Storage: SD and eMMC interfaces
- Display: MIPI D-PHY-based display connectivity and LVDS support
- Camera: MIPI C-PHY 2.1 and D-PHY 3.0 interfaces, supporting up to 4.5 Gbps per lane for high-speed camera and image sensor connectivity
- Networking and Ethernet:
- Up to 10 × 800GbE or 4 × 1.6TbE connectivity
- Hardened Ethernet MAC, PCS, and FEC
- Hardware-accelerated MACsec security
- Three TSN Ethernet MACs on SoC variants
- PCIe and Expansion:
- PCIe 6.0 x8, with up to two instances on selected devices
- PCIe 7.0 x8 / PCIe 6.0 x16, with up to six instances on selected devices
- Supports Root Port (RP), Endpoint (EP), PCIe bifurcation, and Integrity and Data Encryption (IDE)
- High-speed and medium-speed I/O banks with GPIO support
- High-Speed Transceivers:
- Up to 32 GT SerDes transceivers operating at 256 Gbps
- Up to 176 GX SerDes transceivers operating at 128 Gbps
- GS SerDes transceivers supporting data rates up to 32 Gbps
- NRZ and PAM4 signaling support
- Universal Chiplet Interconnect Express (UCIe) interface for chiplet integration
- Connectivity and Peripheral Interfaces:
- USB: USB 3.1 Gen 2 (10 Gbps) and USB 2.0 OTG
- Serial Interfaces: I2C, I3C, SPI, OSPI, and UART
- Additional Peripherals: DMA controllers, timers, watchdogs, and GPIO
- Security Features:
- Secure Device Manager (SDM) with hardware root of trust, secure boot, and device attestation
- Post-quantum cryptography (PQC) support aligned with CNSA 2.0 requirements
- Protected key storage and physical anti-tamper protection
- Hardware-accelerated AES/SM4 encryption, MACsec, PCIe IDE, and inline memory encryption
- FIPS 140-3 Level 2 certifiable package options
- Package: BGA packages ranging from 27 × 27 mm to 65 × 65 mm
Arm Cortex A720 and Arm Cortex A520 HPS Block Diagram
The Agilex 27 family comes with a new HyperFlow data network that links the FPGA fabric, memory controllers, Arm processors, PCIe and other interfaces. It uses exclusive data paths and DMA engines to move data without consuming FPGA logic resources, reducing routing congestion and freeing up more resources for AI, signal processing and additional operations. The devices also include third-generation HyperFlex architecture for improved performance and logic execution and second-generation AI Tensor DSP blocks for integer, floating-point, vector and tensor operations used in AI and signal processing. Agilex 27 family is supported by Altera’s Quartus Prime Pro Edition FPGA development software. QuartusIQ, an AI assistant, is now available in Version 26.3, making FPGA design, debugging, searching for documentation, and recommendations for easier enhancements.
Altera Agilex 27 Block Diagram
Customers with early access will get Quartus Prime design support for Agilex 27 in mid-November 2026, with engineering samples due in the second half of 2027, the company says. QuartusIQ is already bundled with Quartus Prime Pro Edition 26.3. Pricing has yet to be announced. More information is available on the product page and in the official announcement.
Images used courtesy of Altera.
