VIEWE 4.3-Inch Smart HMI Touch Display Features ESP32-S31
A dual-core 320 MHz RISC-V smart screen featuring 2.4 GHz Wi-Fi 6, Bluetooth 5.4, stereo audio, USB 2.0 High-Speed OTG, and RS485/CAN interfaces for industrial control.
VIEWE’s UES31S043H800V480C-U is a 4.3-inch ESP32-S31-based smart display designed for industrial HMI, smart home control panels, and other embedded applications. The board combines an 800×480 IPS capacitive touchscreen with 2.4 GHz Wi-Fi 6, Bluetooth 5.4, IEEE 802.15.4, and industrial RS485 and CAN interfaces.
Built around the ESP32-S31-WROOM-3 module, the display features a dual-core RISC-V processor running at up to 320 MHz, along with 16MB flash and 16MB PSRAM. It also includes USB 2.0 High-Speed OTG, a microSD card slot, stereo audio with dual microphones, and a 20-pin GPIO expansion header. The board supports ESP-IDF and LVGL, with 18 example projects available for display control, wireless connectivity, industrial communication, and multimedia applications.
VIEWE UES31S043H800V480C-U ESP32-S31 Display Development Board
VIEWE UES31S043H800V480C-U specifications:
- Wireless Module: Espressif ESP32-S31-WROOM-3-N16R16V
- SoC: ESP32-S31
- CPU: Dual-core 32-bit RISC-V processor @ up to 320 MHz with ULP-RISC-V coprocessor
- Memory: 512KB SRAM, 32KB low-power SRAM, 16MB Octal SPI PSRAM
- Storage: 16MB Quad SPI flash
- Wireless connectivity:
- Wi-Fi 6 (802.11 b/g/n/ax), 2.4 GHz, HT20/40, up to 150 Mbps
- Bluetooth 5.4 LE, LE Audio, and Bluetooth Classic (BR/EDR)
- IEEE 802.15.4 for Zigbee and Thread
- PCB antenna
- Display:
- 4.3-inch IPS TFT LCD with 800×480 resolution
- 400 cd/m² brightness
- ST7262E43-G4 display driver, 40-pin RGB interface with RGB666 wiring
- GT911 capacitive touchscreen controller over I2C
- Storage: MicroSD card slot with 4-bit SDMMC/SDIO 3.0 interface
- Audio:
- ES8389 stereo codec
- Dual NS4150B Class-D amplifiers
- Two onboard analog microphones
- Left and right speaker connectors
- USB:
- USB 2.0 Type-C for 5V power, firmware flashing, and serial debugging via CH340C
- USB 2.0 High-Speed OTG Type-A port (480 Mbps)
- Expansion and connectivity:
- RS485 interface with SIT3088E transceiver and automatic direction control
- Classic CAN interface with SIT1050T transceiver and ESP32-S31 TWAI controller
- 6-pin industrial terminal block for RS485 and CAN
- 2×10-pin GPIO expansion header with UART, I2C, GPIO, 3.3V, 5V, and GND
- 4-pin UART connector
- Misc: Four ADC buttons, BOOT and RESET buttons, WS2812B RGB LED, optional passive buzzer
- Power: 5V via USB Type-C
- Power consumption: 320mA typical and 500mA maximum with backlight at maximum brightness
- Operating temperature: -20°C to +70°C
VIEWE ESP32-S31 4.3-inch smart display board showing main components, connectors, and interfaces
On the software side, teh company provides 18 ESP-IDF examples covering LCD and touch control, LVGL, Wi-Fi, Bluetooth, RS485, CAN, USB HID, audio recording, and media playback. The examples also include an MP3 music player and AVI/MP4 video playback from a microSD card. The company maintains a board support package in the Espressif Component Registry, along with schematics, documentation, and example code on GitHub. The BSP includes LCD timing improvements and fixes for audio configuration and SD card power control.
The ESP32-S31 is still a preview device, so you need to use the ESP-IDF master branch with the –preview option to build firmware. Arduino IDE examples are still being adapted, and PlatformIO examples are not yet available.
The VIEWE UES31S043H800V480C-U is listed on the VIEWE web store for $38.99, discounted from $40.00, and is currently available on backorder. More information, including schematics, example projects, and programming instructions, is available on the company’s GitHub repository and technical Wiki.
VIEWE 4.3-inch ESP32-S31 touchscreen display with dimensions.
Images used courtesy of VIEWE
