Jump to content
Electronics-Lab.com Community
What Chip Converts Decimal to Pulse ..?
Mhz
Hello, I'm trying to find out what chip converts Decimal Numbers to generated Pulse Output...?
In other words, If I have a keypad and press the number 5, and want to have 5 Pulses of output, what chips would perform this action?
I guess I would prefer a square wave type Pulse.. But not particular.. Thanks For any Helpful Info In Advance...
Link to comment
Share on other sites
First you need an encoder to give you the binary representation. This goes to a multiplexar. The selects can be cycled with a counter that is clocked at the frequency you want. Let's say the clock time is 1 ns. The counter will increment every 1ns. This means the select will change every 1ns. The data will be presented at the output with a pulse width of 1ns.
Link to comment
Hi Kevin,
A whole ns? Then your counter will be running at 2GHz.
Isn't that frequency a bit high for a simple keyboard multiplexer?
Link to comment
So when the Binary number is input to the Multiplexer, the Multiplexer will take that binary number and convert it as the relative pulse count at a certain pin in relation to the clock frequency that is applied to the Multiplexer?
Are there any schematics that support such an operation that I can view? Thanks
The reason I ask, is because there isn't much if any thing over the Internet explaining this chips function in full...
Link to comment
It is easy to implement this. You just use the standard components. The output will be a train of data with a 1ns pulse width for each bit. When it's done, the next bit will be a repeat of the sequence. A 5 will look like this assuming a 4bit encoder :
0101 0101 0101 0101 until the next number is pressed. The counter will have to be a two bit. A count of 00 will select the 0, a count of 01 will select the 1, a count of 10 will select the 0, and a count of 11 will select the 1.
Link to comment
Thanks kevin, I think I'm going to need a data sheet of a Multiplexer to fully understand the principle.. I am attempting to make a mechanical movement of a stepper motor that will correspond to movements via a digital keypad.. In other words, if I push key 5, I want the motor to step 5 times ..(Just for experimentation). I want this project to be free of computer input (serial, usb parrallel) and free of microncontroller input..
Link to comment
Wait a minute, Mhz,
Kevin's counter doesn't output the number of pulses that you want, and neither does his multiplexer.
A counter can be preset by a binary input to a certain number that it starts counting from. Then its outputs count up or down from there. You could preset it to "5" from the keyboard's encoder and have it stop when it counts down and reaches "0". With a multi-input gate connected to all counter outputs and the clock, the output of the gate will be the 5 clock pulses that you want. The same thing will happen with any other keyboard-to-preset number.
One kind of multiplexer simply "selects" multiple inputs and outputs them, one at a time, usually in sequence. Another kind of multiplexer simply "steps" its multiple outputs, one at a time, and has a single input. I don't see any requirement for a multiplexer in this circuit. Kevin says that the multiplexer "selects", but there is nothing to select from, since there is only one keyboard encoder that can directly feed the counter's presets. A keyboard encoder sometimes has a multiplexer built into it, but that is also not required here.
You will need additional circuitry such as a flip-flop and a multiple-input gate from the encoder to start the clock when you press a button and to keep it going until the counter output reaches "0".
Link to comment
Hello audioguru, and thanks for the info... The question I would like to inject in this decimal to pulse quest would be:
What is it that a standard touch-tone telephone use, when you set it to pulse instead of tone, When you select pulse out for a telephone, you can actually push a decimal digit and actually here the pulse click the number you pushed.. What are they using for this? Thanks for the help..
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
