Dido Posted August 24, 2004 Report Share Posted August 24, 2004 Hello, I really need help I broke my Sony Walkman and I found out that the left channel is not working because of one 8 ohm small SMD resistor so I`m thinking of soldering a new one but the problem is that these resistors are even smaller than the regular SMD types. Pls for help If someone has got experience with SMD components. Quote Link to comment Share on other sites More sharing options...
trigger Posted August 25, 2004 Report Share Posted August 25, 2004 I think it may be an 0402 size component. The soldering method is the same as other size but suggested to use a sharper solder iron to do so. Quote Link to comment Share on other sites More sharing options...
Dido Posted August 25, 2004 Author Report Share Posted August 25, 2004 Ok The iron I`m using is a 25Watt one but I remove the "hooter" of the iron and I put a 1.5mm thick copper wire without the isolation sharpen in the end.That`s how I usually solder these components. I have experienced with electronics very much but I haven`t had such a problem until now. Quote Link to comment Share on other sites More sharing options...
Dido Posted August 25, 2004 Author Report Share Posted August 25, 2004 These IC`s are very sensitive so you shouldn`t solder them with a 230V iron.I use a 6V one but if you don`t like to spend so much money you can try this way1. You wait for the iron to get hotter 2. You turn it off and start soldering when the iron gets cold you turn it on again and like that....... Quote Link to comment Share on other sites More sharing options...
trigger Posted August 25, 2004 Report Share Posted August 25, 2004 Ok The iron I`m using is a 25Watt one but I remove the "hooter" of the iron and I put a 1.5mm thick copper wire without the isolation sharpen in the end.That`s how I usually solder these components. I have experienced with electronics very much but I haven`t had such a problem until now. It is a nice idea but the copper wire will stick with solder and may mess up your work......My experience is to use sharp solder iron (25W is fine) + thin solder (0.6mm) + tweezer + solder paste , then everything will be nice. But somehow beware of the solder stick to adjacent components' pads. Quote Link to comment Share on other sites More sharing options...
Dido Posted August 25, 2004 Author Report Share Posted August 25, 2004 Posted by: sasi Posted on: Today at 03:14:48am Your question was"How do I solder SMD components with a regular iron"Are you using a 6V iron regularly ? Dear sasi I think that a regular iron means an iron with a regular "hooter" thick 4,5 mm that`s what I mean with this. Quote Link to comment Share on other sites More sharing options...
Dido Posted August 25, 2004 Author Report Share Posted August 25, 2004 Yeah I mean with the word "hooter" a soldering tip what`s the smallest tip you`ve got. Quote Link to comment Share on other sites More sharing options...
steven Posted November 6, 2004 Report Share Posted November 6, 2004 :)if your soldering tiny parts the use of a thin or fine tip , low tempiture soldering iron is usefull and a pair of tweezers to hold the part in place, you will need some fine soldering wire to help, you can allso use blue tac to hold a tiny part in place till you solder it. the blue tac will get soft from the heat but when it cools you can remove it with another peace of blue tac Quote Link to comment Share on other sites More sharing options...
surajbarkale Posted November 18, 2004 Report Share Posted November 18, 2004 First get the component correctly mounted then just solder without caring for shorts between pins. Finally remove the excess solder with desoldering wick. You have to fry a few components during initial ventures but once you get the hang of it nothing is simpler. Quote Link to comment Share on other sites More sharing options...
