Jump to content
Electronics-Lab.com Community
Sign in to follow this
ashtweth
over unity is here
hi all, i have just been invited here by kumaran, and have enough infomation to keep you all on track, i was asked about adams, motor and bedini, i can say bednini and gray use radiant energy
now i will direct you to the yahoo energy group called 'free-energy'
do a search and join!!! look for me there ashtweth_nihilistic
there has been numerous discussion about teh bedini motor and how to get it working even the current post are there now, i suggest you also look for ellias remington, and all posts by him, he calls himelf hector!!
here is the essential pdf you need to understand transformation to atcheive over untiy in these devices
http://217.159.169.126/~creator/public/ZPE/files/consolidated_knowledge.pdf
hector writes
The WHY of ZPE and were OU comes from is Explained in this E-book
ZPEV2.pdf
Found here
http://groups.yahoo.com/group/EVGRAY/files/A.R.K%20%20%20FILES%20/
with 3rd GENERATION recovery circuitry all you need is to built the
devices (AS RV & others descripted there to verify it ..
AS MEG Bedini theory is FLAWED, its construction is OBSOLETE .
Energy comes from a transformation effect that can be replicated
modifiying standard motors , I had given ROTOCONVERSION PRINCIPLE
FREE to Humanity, EASER OU principle also to OPEN a window to its
universal Use ..
The Spark gap creates a series of PULSED discharges that are
responsible for Modulating the core material into a LASER alike
state were ENERGY IS TRANSFORMED From Thermal-Atomic & magnetic
component to the Electrical one ... SLC 1983 On Energy savers lamp
development TESLA technology Aplication.. Genesis transform
theoretics .
I state again OU is transformation , pumping energy from one form
into another were it can be used ..
AS MEG, that Patent becomes an Stumbling block toward alternate
energy development (I see so many MEG replications being Used) ;P
and is overdue to be at sale In SEARS and Pepboys (get one ! );b
RV ? you can make your OWN with no FBI or NSA coming to arrest you !
as its Published non-patented free domain (free) . so keep it free
like linux and improve on it all you like & pass it on!
I Cannot judge werever Bedini had this Information or the Circuits
before I gave them Public years ago ..
One thing is clear , If there was NO patent and I Published FIRST
wile he HELD his NON patented Knowledge SECRET that is his problem !
ITS called synchronic parrallel development were similar ideas are
developed simultaneously by different persons with no knowledge of
the other .
Konzen Well Knows I published First Diode recovery system and simple
negative switching positive bias circuit...
He has Improved on it with his OWN effort using it in BEDINI motor
aplications , as I gave RESONANT tuning concept public too ..
Used by Raivo In Estonia In his own advance Resonant aplication also
to a BEDINI motor with incredible POWER increase ...
OU extraction :
Its already FREE domain, Anyone is free to challenge that patent
searching my old notes & publications all over the net .
I DONT INTENT to PATENT RV as iS given as PUBLIC DOMAIN Copyright
nor intent to patent OTHERS effort that are put into it ..
I had Explained and publish notes on PM Permanent Magnet RV
construction ,power factor correction & others I allways welcome a
JOIN venture of all of us within a Forum to Exchange this Ideas
in free domain with due credit ..
As I welcome a Comercial-institutional join venture to grab OU by
the horns in an Unified R&D consortium were everybody can benefit
(not 3rd party greed mafia)were inventors are left hi and dry ..
NEWMAN,Motor , MEG , Bedini Motor , & all this devices WORK under
same PRINCIPLE ...
Like TESLA took Edison DC to AC I had Taken OU DC principle to AC
demostrating the ROTOCONVERSION EFFECT .. (Public)
Now being Replicated by Many ... (Given as FREE domain )
Bedini motor can be Used as a GENERATOR driven by an RV (As is
improved more )actualy RV power turns it to pieces at its 3450 RPMs.
speed, rotor drag and valance & bearing problems are solved
using RV reverse dynamometer diagnostic capability so BEDINI motor
can be improved to real practical USE within standard off the shelve
hardware .
I invented RV to be USED as a primary R&D tool in ZPE research ...
constructed using STANDARD easy to get PARTS...
Bedini Patent Notches inside what is already free domain.
Its my duty to Point at it ...
I built his "Unipolar" motor and understand it ...
The plasma dynamics are another OU aspect not directly related to
the motor.
See ZEUS lamp development
20/fl40.zip
you can get OU out of any FL lamp tube, a Russian did it before
me.
Can he say the same about RV ? Did Bedini tested RV ??
It did not work for him ? OPPS! he did not know how to make it as
per instructions ??
LOL! :)
Hector-end
hector is the inventor of the rotor verter!! mentioned as RV above!! here is additional infomation and a video, you will have to join the groups to view it, dont worry it takes seconds!!
http://groups.yahoo.com/group/EVGRAY/files/A.R.K%20%20%20FILES%20/invertermotor_wm9.avi
OK that is Rain & raivo experiment Video ..
The computer provides a FRECUENCY to a transistor inverter this
drives a transformer as to provide RV with power ...
What is found here is the OPTIMAL frequency were the motor is more
efficient (were Usualy OU manifestation occurs ..)
In tesla coil Spark gaps are adjusted to tune it to best
performance ..
In motors and transformers a combination of 4 factors can be Used
in case of AC "frequency and amplitude voltage "
in case of PULSES , VOLTAGE & * pulselenght *
At a given Voltage & pulselenght any coil will deliver OU as an
EMP , This as magnetic field generated from pulse collapses within
the coil ...
More detailed info is in the E-book ..
i am also invovled in an alt energy copany soon to have its license, hopefully i can give you all a job soon!! :D
Share this post
Link to post
Share on other sites
Hi ashtweth,
Thanks for accepting the invitation. So you are working on RotoVerter system?
Me still working on Adams motor and Bedini Motor. Just today posted some unofficial result got from yestedays testing in "Electronic Chic Chat -> Adams Motor Project". Have you read through the thread?
Keep working towards OU. I believe the truth is out there.... Just waiting for us to discover it.
Share this post
Link to post
hi guys, yes i recomend you join the yahoo groups, all the people that have working over unity devices are there and can assist you, look for free-energy or goto overunity.com and it will re direct you there, and one of the best that hector frequently visits is EVGRAY
just type that in for your search in yahoo groups.
kumaran, you must work on the Rv to essentially understand radiant energy states, its the same transformation, hector states this, you will never get any of these motors going unless you educate your self in the trnsformation process.
yes i am going to replicate the RV.
sorry about the length, but its infomation you cannot afford to be with out, did you all read the pdf?
Share this post
Link to post
ashtweth,
I wish you luck for the RV project. Konehead succesfully replicated it. Konehead is a very hardworking person. I always follow his experiment reports.
RV project will cost more money compare to adams and bedini motor such as buying quality 3ph motors and so on.
Right now my budget is a bit tied. Let me focus on least expensive project first before go for RV.
If I got time and money, I definitely will go for it. I saw your postings in Yahoo. Hector already give you green light for you to proceed. Just keep up your good work and never loose interest.
Regards,
Kumaran
Share this post
Link to post
hi mate, i am approching a uni in south australia so it becomes academic, if you have the know how to put these together let me know , mayby i can end some funds to get it replicated in your area, i will be looking for people to help with my alt energy company panacea, so i hope i can give you all jobs :D
this is the only tool worth putting money together!! never mind the nerdini or adams, we have a better learning tool machine to work on here ;)
which country are you and every one cituated?
Share this post
Link to post
ashtweth,
You are really going for it. Good. By Konehead's postings in Yahoo, the result shows impresive earlier but recently he mentioned he still haven't get OU. Very confusing. Is this because of PM generator he was running?
Malaysia.
Share this post
Link to post
The posts on this forum should not be dependent upon posts on another forum. There is no reason a complete conversation cannot be made here.
MP
Share this post
Link to post
yes ofcause.
ok lets start with the rv from the description, who in malaysia is willing to take on the project with my help (funding) it looks complicated but im assured is workable by off the shelf parts.
lets start with the description of the prime mover and from the schmetic can we discuss this?
here is a good one
http://www.theverylastpageoftheinternet.com/ElectromagneticDev/arkresearch/rotoverter.htm
kumaran, im not to sure, yes im following how he is trying to reconfigure to pm, looks complicated but is one of many options available stated by hector for the rv. we will have to wait and see i guess??
Share this post
Link to post
Ante,
Sceptic is normal. I was sceptic before. Law of Physic says, output always lesser than input. There is no such device or product in the world that can output more energy compared to input until today. Yes I agree, but soon there will one in near future (I believe).
Ashtweth,
Talking about RV, what konehead explained in Yahoo forum make sense. In normal AC 3PH motor, you can't really adjust the stator and rotor gap. While in pulse motor (plate based like Muller motor), this can be easily achived. More over if the motor can be configured in single stator and double rotor, both poles from the stator can be utilised to push turn rotor faster with the same amount of input power (more RPM and torque).
For generator section, you may look at
http://homepages.enterprise.net/hugh0piggott/pmgbooklet/itpmg.pdf
PMG used in Wind Generator. With less RPM can get higher Wattage. This type of generator uses air core stator so there won't be any cogging effect when the rotor turns. Can ever turn by hand easily. Since it is heavy, it can add flywheel effect for pulse motor which is highly recommended. What do you think about it. Does it make sense. Please revert. TQ.
Share this post
Link to post
Well this is the way it is: For every transformation of energy there are losses. Even a piece of copper wire has its resistance and there are not much you can do about that. If putting together things like motors, capacitors, inverters, alternators, and generators they all add to the losses.
Share this post
Link to post
hi guys.
thats a great pdf kumeran!! i wish the rv pdf was as detailed as that!!, thanx for the clarity guys, you are both obviously incisive enough with the expertise to be able to follow this closely.
so how about we attempt a replication?, and walk through of the whole process.
with antes permission i would like to provide the funding, and will need the communities help in building this project.
kumeran, what parts do we need, and what qualifications would we need to be able to put this RV together?
ante any suggestions mate?
Share this post
Link to post
Ashweth,
What do you mean suggestions, where to start or choice of material or what?
Kumaran,
I like the idea of using a harddrive, good bearings, good balance and easy to get. The core for the coils is a bolt, this is steel and not optimal for a magnetic core. Try to get
Share this post
Link to post
Ante,
Finally you are suggesting something to try out. ;D I appreciate it thanks. Actually, I wanted to use soft steel as you have suggested but I couldn't get one. I have searched all the hardware shop at my place, but can't find any. Even I bring sample soft iron taken from transformer and show to hardware shopkeepers. They don't know where to get this items. So the closes to this item is steel bolt. Also I find it easy to wind copper and mounting.
You have asked about the schematic drawings in another post. Sorry, I didn't draw one. This is because I was changing the circuit so often during experiment. Don't get mad. Still got a lot of experiments and motors to be built. For newer motors I will prepare those schematic and experiment result as complete as possible and post it.
Share this post
Link to post
Everybody, :o
Overunity experiments are currently being tested at http://peswiki.com/index.php/Directory:Bedini_SG. Just follow the progress and see if they could achive overunity. They need one month (30 days) continues experiment to prove overunity. Sterling started to collect data since Oct. 10, 2004. The experiment should be completed by Nov. 10, 2004.
This site is complete with all the information needed like overunity theory, material required, schematic diagram and lots more. Happy readings. ;)
Share this post
Link to post
Ashweth,
Kumaran,
Share this post
Link to post
Simple test on OverUnity got it from forum.
Hi all,
This is a very simple O/U circuit that is simply designed to show
anyone that O/U can be done as it a reality. Loads of people have
done this already, but it blew my mind and I thought I'd bring it to
anyone who hasn't see it already. Heres my replication:
Get:
1) one 10v 100uf cap and one 63v 100uf cap.
2) a low voltage LED(like on circuit boards)
3) a fully charged 9v ni-cad battery
4) a digi-volt meter
OK. Ground both caps to zero charge. Then touch 10v cap to 9v battery
to get a charge in it. Take a very quick reading on 10v cap with
digimeter and write it down.
Then connect 10v cap to 63v cap in series.( + - + -) so that there
are two legs remaining one from each cap. Secure these caps down and
complete the circuit by touching the LED onto both legs.
The LED will flash VERY briefly as the circuit is completed. Thats
it!!! Put LED down. Now take readings of both 10v cap and 63v and
write down. Now heres the good bit. Heres the result of my first test.
10v cap at 8.43v before comepleting circuit.
10v cap at 6.49v after
63v cap at 2.52v after. End result = 6.49v + 2.52v = 9.01v!
You have lit the LED and transfered charge into the larger cap, but
you havent lost any charge in the process. YOU HAVE GAINED CHARGE!
Here's my 2nd and 3rd results, I did the same test 10 times in all.
Each time ground the caps and starting from the beggining.
2nd.
10v cap at 8.67v before.
10v cap at 6.92v after
63v cap at 3.36v after. End result = 6.92v + 3.36v = 10.28v
3rd.
10v cap at 8.70v before
10v cap at 6.67v after
63v cap at 3.76v after. End result = 6.67 + 3.76 = 10.43v.!!!
Whats happening. Simply when the LED flashes a tiny magnetic field is
produced which opens a field to ZPE(or radiant current). For this
brief milisecond this field flows through the LED and into the larger
cap until LED turns off.
There is no other explination on how more total charge can be
obtained AFTER doing electrical work in a circuit. O/U and ZPE in
there simplest form.
Anyway, i said it would be simple, but it does work and at least it
works!!!
Bill.
Share this post
Link to post
Have you measured the voltage accross capacitors after connecting them in series?
The charge equation for the capacitor is -
Q = C*V
When you connect two capacitors of same value (100uF in your case) in series, resulting circuit will have half the capacitance (50uF). So the voltage across the circuit will be doubled to mentain the charge. Similarly voltage will halve if you connect two capacitors in parallel.
This won't happen if both of them are charged.
BTW what is the full form of ZPE?
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
