Jump to content
Electronics-Lab.com Community
0-30V Stabilized Power Supply
redwire
I don't understand you. You are saying, like my circuit was perfect. But I am telling you, that LED is always on, without a load...
I know that your circuit works wrong. I explained how it is supposed to work so you can fix it.
1) U3 works wrong so double-check that its inputs are not connected backwards or shorted together.
2) Make sure that the output pin 6 of U3 is not shorted to ground or to -1.3V. What is the voltage of pin 6?
3) Make sure that pin 7 of U3 is about +24VDC.
4) Try replacing U3.
Link to comment
Share on other sites
Thank you audioguru, I am closer now. I figured out, that I turned Q3 backwards. But still, it doesn't work perfect. At current adjustment pot turned to lowest value, LED is not on. It turns on somewhere on the end of turn of current adjustment pot.
Voltage of pin 6 is 28V, when LED is not on. When it turns on, it falls to 13-10V.
Pin 7 is always 24V or higher. All pins of U3 are ok.
The LED is turning on with unknown reason. The voltages on U3 changes like I said with changing value of current adjustment pot. What do you say? Could be Q3 fault?
PS.: all measurements applies to NO LOAD..
Link to comment
Hi Fikic,
With no load on the project, the output pin 6 of U3 should always be high at about +24V to +28V. So it does not reduce the output voltage through D9 and it does not turn on Q3 to light the LED.
The slider of the current adjusting pot P2 applies a small positive voltage to the (+) input pin 3 of U3. The voltage should be +0.005V when P2 is turned to minimum and should be +1.414V when P2 is turned to maximum. Without a load, there is no voltage across R7 so the (-) input pin 2 is 0V. Then the output pin 6 of U3 should be always be high.
What range of voltage at pin 3 of U3 do you measure when P2 is turned from minimum to maximum?
Maybe the terminals of P2 are connected wrong.
Maybe U3 is defective. Replace it.
Link to comment
Hi Fikic,
P2 is connected ok. When P2 is at it's minimum, the voltage on pin 3 of U3 is 15.05mV, at it's maximum it's 2.07V. Is that normal? At P2 minimum, the voltage on pin 2 of U3 is 45.5mV, at it's maximum is 95.5mV. So there is voltage drop on R7 in any case. Why is that?
PS.: Is normal, that when I connect a load on PSU, just Q4 and Q5 get warm, Q2 is like nothing is on it..
Link to comment
R7 is 0.47 ohms so with 95.5mV across it the load current of the project is 203mA which is 28 times too high. The current should be only 5.6mA in R4 plus 1.2mA in P1 plus 0.56mA in R6.
Check the few connections along the output of the project for a connection to something that is wrong.
Is normal, that when I connect a load on PSU, just Q4 and Q5 get warm, Q2 is like nothing is on it?
The heating in Q2 depends on the voltage across it and the current in Q4 and Q5 and on their amount of current gain that could be only 35 or could be more than 100. When the load current is 3.0A and the output voltage is low then Q2, Q4 and Q5 heat the most.
Link to comment
The voltage drop across R7 is just 5mV. 95mV voltage drop is just on pin 2 of U3.
Link to comment
But R21 is supposed to be 10k and it connects pin 2 of U3 to R7. When current-setting pot P2 is minimum then R21 has a max of 0.5uA (for an MC34071 opamp) to 2uA (for a TLE2141 opamp) of input bias current which makes pin2 a max of 5mV to 20mV, not 95mV.
This input bias current in R21 turns off the current regulation when the load current is low.
Yesterday I explained why R7 has a small voltage drop when there is no load current.
Link to comment
You didn't understand me. At P2 minimum pin 2 of U3 is 45.5mV, at its maximum pin 2 of U3 is 95.5mV. Anyway, Too high...
Link to comment
Good evening. Sorry for my broken English. I have a transformer with a winding 24 volts 5 amps. Can I use the original scheme, but with TLE2141A can use the original scheme? Or that I get with this transformer, if you make schema changes? I want to output current 5 A, you need to change in the scheme?
And yet. Can I make my own scheme? does it work?
Thank you for your reply.
Link to comment
For a 5A output at 30V, the transformer must supply a peak DC voltage of about 39.6V to the rectifiers at 5A which is 198VA.
You can use a 28VAC transformer or a 30VAC transformer at 7.07A.
The modification to the latest 3A schematic for a project with an output of 5A is to add a 3rd 2N3055 output transistor with a 0.33 ohm emitter resistor, change C1 to 20,000uF and change R7 to 0.27 ohms at 10W.
Link to comment
hi all specially Audioguru,
i build with mc34071, 24VAC transformer and picmaster PCB layout... yesterday i blew two op-amp U1 and U2. i trace from u3 when i turn P2 until 3.4-4.0V on R18 u3 and ZD 10V become very hot. and i think when those op amp blew i set the P2 more than 3.4V.... what's wrong?
regards,
ali
Link to comment
U1 has a light load so it should be cool.
U2 has a little more work so it should be warm.
U3 has a light load so it should also just be cool.
Since U3 has a light load then the 10V zener diode that powers it should also be cool.
P2 is the current-setting pot. Its voltage is simply a reference voltage to opamp U3. U3 reduces the output voltage of the project when the load current is higher than the setting of P2.
Link to comment
after browsing old posting. i found that picmaster pcb drawing has a fault on C10 or C3 if using audioguru schematic it is + and - of the capacitor is backward in the pcb. and i found mine was backward and it is now shorted maybe this is the cause of the U1 and u2 blew?
C3 on my schematic filters the -1.3V supply which has nothing to do with opamps blowing up.
With C3 shorted then the current regulation will not work if the output of the project has a very heavy load at a very low voltage or if the output is shorted. Then U2 might blow up and Q2, Q4 and Q5 also might blow up.
Link to comment
  • admin featured and pinned this topic
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
