Jump to content
Electronics-Lab.com Community
0-30V Stabilized Power Supply
redwire
The voltage from your transformer is far too high for this project.
The transformer is marked "98VA". A transformer does not consume power (Watts), instead it passes power (VA) so its power is rated in VA, not in Watts.
Your transformer does not show its rated voltage. 24/91 are just meaningless numbers that might be when it was made: the 24th week of 1991.
You need a transformer rated at 28V to 30V with a power rating of 119VA to 127VA.
Link to comment
Share on other sites
Is there a problem if the transformer is 200VA?
Link to comment
A 28V/119VA transformer will operate at its max allowed temperature when the power supply has a 3A load.
But a 28V/200VA transformer will be pretty warm, not hot when the power supply has a 3A load.
Of course the 200VA transformer is heavier and costs more than a 119VA one.
So there isn't problem if 200VA is used. I know that it costs more, but ony that one I found, for now. Thanks!
Link to comment
In PicMaster's scheme are used 1x12000uF 63V capacitor or 2x6800uF 63V capacitor. Can be used something smaller or on lower voltage? There ones cost much, and hard to find.
I also recommend 12000uF.
You need a total of 12000uF for low ripple. Use hundreds of small capacitors in parallel if you want and if your enclosure has space for them.
If the voltage rating on the capacitor is too low then it will fail.
Link to comment
Guest 9waste9
hi guys i am new here , came to this website by searching for a power supply , and i found it in here
http://www.electronics-lab.com/projects/power/001/index.html
But without going deep into the design (the reason was i trusted this site ) , i just bought all the components in the parts list , and only then did i see the flaws in the circuit . I really don't want to do the modified circuit , is there any way i can carry on with the original design ??
  can i not just connect the pin 7 of the tl 081 op-amps to a 7815 regulator ??
Link to comment
Guest 9waste9
Thanks for your reply audioguru , maybe i can do exactly what ivan suggested
"    Received the following email from Ivan on 02/2010:
    Ok. I bulid your project about a day ago. Mounted all the parts on the pcb and then concluded that there is some serious problems in this schematics. First, 2N3055 will overheat, so you have to connect two of them in parallel with emitter resistors 0.1ohm/5w. Second, maximal voltage between '+' and '-' of TL081 is 36VDC.If you connect them as it is shown in this circuit diagram that voltage will be about 45VDC, so they will burn down immediately. To fix this problem you have to reconnect all pins number 7 of U1, U2 and U3, emitter of Q3 and 'upper' end of R19 to out of an 7809 with 18V zener diode between 'common' pin and '-' of 3300uF cap, and input of 7809 connect to '+' of the same cap. Now, on pin number 7 and mentioned parts you'll have 27VDC, and total voltage will be 32.6VDC. Third, instead of using 3300uF, use 4700 or 6800uF/63VDC to reduce the ripple on higher currents (2-3A). The rest of the circuit is perfect. I like it cause it is so inexpensive and easy to make with those simple reconstructions i mentioned.
Link to comment
Guest 9waste9
Ok so the only problem that i see now is the supply voltage of the op-amp . suppose i give an external regulated voltage 0f +30 volts and -6 volts to the 7 and 4 pin of the op-amp, will the problem be solved ??
  I am sorry that i am stressing so much on the original design , since i have serious budget constraints , and buying the high voltage op-amp cost's me four times more than tl-81
Link to comment
You could do what I did went to the Texas instruments web site and ordered some samples then you get them for free.
You need to listen to audioguru the old design has many faults, I have ben there and done that tried everything to get the old design to work but in the end it went in the bin and I designed my own PCB of the upadted schematics and have had no problems.
There is lots of information in this topic.
Link to comment
Waste, you don't say which country you are in. I usually go to Digikey and buy opamps.  MC34071 opamps cost only $1.02US each and TLE2141 opamps cost only $1.71US each today.
For comparason, the original circuit's TL081 opamps cost $.52US.
So the cost for only 3 of them is almost nothing.
But many other parts also need to be replaced.
Link to comment
Guest 9waste9
ok audioguru , i will listen to you so is this the new design ??
http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=19066.0;attach=16230;image
also is this the part's list ?
http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=19066.0;attach=16238;image
or this one
http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=19066.0;attach=16240;image
please confirm .
Also i am planning to use the 3055 power transistor in to-220 package with a heatsink , instead of to-3 package , since im a poor guy
Link to comment
This is my version of the PSU , All tested all working no problems complete with PCB and BOM aslo with connection drawing, I mounted the transistors on a seperate PCB but you don't have to use the PCB you can just hard wire them.
i've build this one from PicMaster, but on first attempt i got little firework with fog, both U1 and U2 are gone (cracked) :( does anyone have advice what can be wrong? i have C8 ~ 20000uF
could it be due to power transistors? (transformer, and 2n3055 's are the only parts which survived from my last attempts)
How can i troubleshoot it?
a) can i remove OPAMPS?
b) can i disconnect power transistors?
c) what else i can do?
Link to comment
U1 has nothing to do with any transistors. It is an 11.2V reference that is fed power through a 10V zener diode so its power supply is only 30V.
U2 operates with a +41.7V total supply. Its max allowed supply is 44V.
Opamps smoke and crack if their power supply voltage is connected backwards or if the supply to an opamp is AC instead of DC.
Corrected math.
Link to comment
I never had that problem, Have you checked that the bridge rectifier is correct ?
I used one like this from here
http://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Bridge-Rectifier-Diodes/4A-8A-In-line-bridge-rectifiers/29673
It's like audioguru stated it must have been power supply voltage is connected backwards or the op-amps aren't the correct ones. Has it is remover U1&U2 and see what voltage you have got on pins 7&4.
Or have you found your error or a fault, means you thaked audioguru but you do not say if problem solved
I know my design works 100% otherwise I would of not published it
Link to comment
  • admin featured and pinned this topic
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
