Yes.
When finished your layout you can submit it to JLCPCB for their checking.
Naturally there are design rule checks you can set when you do the "generate PCB".
After that you can ask for a price, watching your delivery options as I mentioned previously.
As with anything, you have to learn how to use the software.
It is NOT just open up and work.
I had to learn so you can as well without thinking you can jump straight in to the deep end.
Hint on resistors, it depends on what size and type you select in the common library.
