thiagoas
- Jan 1, 1970
- 0
That voltage supressor will help a lot, try it.
Tell me how you'd select this device and where would you recommend placing it in the circuit?thiagoas said:That voltage supressor will help a lot, try it.
Good points. I didn't suggest using it, just that it was on the right track.audioguru said:The circuit at diyfan.blogspot has some of the problems of the original circuit here plus one:
1) The new problem is that the datasheet for the TL081 shows that its negative supply should be a minimum of 4V so that its inputs work properly all the way down to ground. Then when you add the +33V supply the resulting 37V is higher than its maximum allowed supply of 36V. The TLE2141 has a max supply of 44V and does not need a negative supply.
2) When you calculate the minimum beta for the driver and output transistors then the maximum current required from the TL081 is 1.6mA and its maximum voltage drop is about 2V.
The total maximum voltage drop of the Vbe of the driver and output transistors is 2.1V. The maximum voltage drop of R14 is 1.6V. Then the total voltage drops are 2V + 2.1V + 1.6V= 5.7V so the maximum output at 3A is only 33V - 5.7V= 27.3V if the main filter capacitor has no ripple (but it does have some ripple).
3) If the output has a low voltage or is shorted then at 3A the output transistor heats with 40.4V minus 1V for R7 = 39.4V x 3A= 118W. It will melt.
Fixed your url.thiagoas said:In a company that I used to work they use this suppressor. http://www.littelfuse.com/~/media/Electronics/Datasheets/TVS_Diodes/Littelfuse_TVS_Diode_P6KE_Datasheet.pdf.pdf
I would put a bi-directional on the input of AC voltage from the transformer.
This Zeners in the opamps are good too.
The more the better. ;D
I guess you know the 180 ohm resistor reduces the maximum output current to almost zero for an output voltage of 30V. The maximum output current with an output of 5V is only about 150mA.liquibyte said:I have a slightly different circuit than the one shown below
I was gonna say that. heheaudioguru said:I guess you know the 180 ohm resistor reduces the maximum output current to almost zero for an output voltage of 30V. The maximum output current with an output of 5V is only about 150mA.
Yeah, you're right. I was just following a suggestion from somewhere else. I didn't think about the output current when I put this in under no load. If it gets loaded at 3A, the magic smoke's gonna happen. I guess what we're going to have to do is some sort of soft start circuit. The inrush current from the filter cap is wreaking havoc.audioguru said:I guess you know the 180 ohm resistor reduces the maximum output current to almost zero for an output voltage of 30V. The maximum output current with an output of 5V is only about 150mA.
The 10A darlington will have a voltage drop of about 2V at 3A which might be OK.redwire said:How about a soft start such as: .....
I'm going to go with this so I don't have to cut any traces on the boards. I should be able to fit that in my case somewhere. Oddly enough, I already have everything, including some 10 ohm power resistors, except for the relay and mosfet. Even then, I may have something laying around that I could use but I figure I have to order the relay, I might as well get some mosfets while I'm at it.redwire said:How about a soft start such as:
