effenberg0x0
- Nov 22, 2009
- 48
- Joined
- Nov 22, 2009
- Messages
- 48
Sorry, I'm new to Eagle. It was setup like this and I didn't know I could put a white background. Now I know, thanks. I have attached the new image.Why is your schematic a hard to see negative? I changed it to a positive (white background) so i could see it like most other schematics.
Thank God you saw it. I couldn't find TLE2141 or MC34071 in Eagle libs, so I used another opamp that has the pins inverted. Its fixed now.1) Some of your opamps have the pin numbers on the inputs backwards. Some of your opamps have the + and - input symbols backwards. Pin 3 is supposed to be + and pin 2 is supposed to be -.
Yes, I was wrong to use pin1, but schematics I found in the thread show it at pin3. Is it 3 or 2?2) U1 has R5 connected to pin 1 instead of to pin 2.
Fixed3) For C1 you have 3 capacitors in series instead of parallel.
Questions:
1)I have attached the list of Potentiometers and Trimmers in the parts lists of the three versions (Original, 5A, 3A). I'm confused to be honest. I'm building my version with two 30V/5A transformers in parallel and MC34071 opamps. In this case, I guess I should use 10K for RV1, 50K for RV2, 200K for RV3?
2)About the third Potentiometer (1K), I placed it in series with P1. Can you tell me if it is correct?
3)A serious problem: All schematics show an unnamed capacitor (0.1uf) between R19 and U3. I named it CX. I cannot understand why it would be there. Can you give me a hint? I have highlighted it in the attached schematics.
