besarmatis
- Nov 22, 2009
- 11
- Joined
- Nov 22, 2009
- Messages
- 11
Will you try the avr programming for vmeter and ameter?
Yes, definitely. I want my PS to have two outputs. and I got two LCDs here for the meters.Will you try the avr programming for vmeter and ameter?
Connect the + output to ground then the - output is a regulated variable negative supply.karthikeid said:from this circuit can i get a negative power supply or some other circuit is needed??
From this comment could I use this transformer? It is 2x 30V, Secondary Winding:80VA, Secondary Current Rating:2.67A.Your transformer is too small for a 5A power supply.
It is rated at 30V x 5A= 150VA. But the project makes 42.4V so when the output current is 5A then the transformer will be overloaded with 42.4V x 5A= 212VA.
Yes, the 160VA transforer is able to allow the output current of the project to be as high as 3.77A.Timmymna said:Just finished reading this thread and I think I'm going to give it a try.
I have been looking on Farnell's site to find a suitable transformer but I'm a little confused at what specs I'm looking for.
In the latest specs it states a 28VAC 4.3A 118VA transformer, I can't see anywhere that says what the max and min should be.
A few posts back it mentions the voltage shouldn't be too high as to cause overheating and higher power losses but must also be able to provide the current required.
... could I use this transformer? It is 2x 30V, Secondary Winding:80VA, Secondary Current Rating:2.67A.
If I wired the two secondary's in parallel I get 30V with 160VA, giving 5.3A. If the project requires 42.4V then that still gives me 3.77A, (building the 3A version). Also taking into account peak voltage being < 44V for the opamps.
Even the designers of this kit did not calculate the amount of voltage losses there are.I'm not sure if this is correct or if I've taken some stuff out of context, I'm trying to understand how to select the best transformer for the job because there's also a 160VA, 2 X 25V transformer but is the 25V too low? Also it's nearly twice the price so trying to justify which is the better option.
Why will ZD3 reduce the positive supply to U1 and U2 when the transformer is 30VAC? It might cause the max output voltage to be less than 30V when the current is max at 3A.This is my schematic for the power supply
I seen it in an earlier posting so I thoght I'd add it has you could just put wire link if not need but if it is needed and it's not here it make it look unitdy, But if it's not needed then I will take it outWhy will ZD3 reduce the positive supply to U1 and U2 when the transformer is 30VAC? It might cause the max output voltage to be less than 30V when the current is max at 3A.
