audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Here is my schematic and parts list for the 3A project again:
I didn't look at your pcb but the schematic is correct.fikic said:I think, there is no problem with this schematic and PCB.
The voltage on U2 output raises and falls like output voltage if I turn current adjustment pot. The lowest voltage on outpu of U2 is 17V, the highest is 35V (I was meassuring pins 6 and 4??)..audioguru said:When you turn the current adjust pot P2, measure the output voltage of opamp U3. It should stay high at about +22V so it cannot cause D9 to reduce the voltage at the input of opamp U2.
Maybe D9 is leaking and possibly caused by light shining on it.
Look at the datasheet for a BZX85C5V6RL, it is tested at 45mA and its max dynamic resistance at 1mA is pretty high so it regulates poorly. Why don't you use a BZX79C5V6RL that is tested at 5mA?
That is normal when there is a load on the output of the power supply.The voltage on U2 output raises and falls like output voltage if I turn current adjustment pot. The lowest voltage on outpu of U2 is 17V, the highest is 35V (I was meassuring pins 6 and 4??)..
Thank you for your reply~You are trying to make the original circuit that does not work properly and has many overloaded parts.
We fixed it and changed it and the new schematic and new parts list have been posted here many times.
Your 25VAC transformer produces a positive unregulated voltage of only 34VDC which is too low. Your supply will produce a maximum regulated output of pnly 26VDC at 3A, not 30VDC.
The new parts list has a 28VAC or 30VAC transformer and new 44V opamps. The new opamps work with no negative supply and a low voltage negative supply.
Your idea has a positive 34VDC supply and a negative 5.6V supply which is a total of 39.6VDC when there is a full 3A load and a total of maybe 43VDC when there is no load.
But the original TL081 opamps and the ones you are talking about have an absolute maximum allowed total supply of only 36VDC.
The new circuit has a positive supply that is +37.6V to +42.4V. It has a negative -1.3V supply for one opamp. Then its maximum total is less than the 44V max of the new TLE2141 or MC34071 opamps.
The old opamp and the opamps you are talking about do not work without a negative supply or a negative supply as low as -1.3V.
Yes, it has and if I connect a load on it the voltage drops unnormally and there is no power. What could it be?audioguru said:That is normal when there is a load on the output of the power supply.
When you turn down the current-setting pot then the current regulating circuit reduces the output voltage to keep the output current at the setting of the current adjustment pot. The LED lights to warn you that the output voltage is not regulated anymore because the current-regulating circuit is reducing the output voltage.
Your circuit has a serious problem if the output voltage drops when you turn the current adjustment pot and there is no load current.
Of course it didn't work without C1.I made a mistake when I was drawing schematic. I didn't connect - of C1 to gnd. I corrected PCB now, and PSU works when I connect a load.
That is normal. it regulates the output current by reducing the output voltage which reduces the output current according to Ohm's Law.when I turn pot for current regulation, the voltage drops.
The LED should turn on only when it is reducing the output voltage.LED is still on the whole time.
That is normal. The output voltage of U3 drops when it regulates the output current and it turns on the LED.Now the voltage on output of U3 is 24V but not all the time. In some cases it's 17V when I turn current adjustment pot.
All this I wrote applies to the case, when I have no load on output...Of course it didn't work without C1.
fikic said:Then it is easy to fix.
Without a load, there is no current in R7 then it has no voltage drop so the (-) input of opamp U3 is at 0.0V. But The current-setting pot P2 has a small positive voltage from R18 and the current trimpot so the (+) input of U3 is at a positive voltage which makes its output go high which stops current regulation from reducing the voltage at D9 and stops transistor Q3 from lighting the LED.
audioguru said:I don't understand you. You are saying, like my circuit was perfect. But I am telling you, that LED is always on, without a load...
I know that your circuit works wrong. I explained how it is supposed to work so you can fix it.I don't understand you. You are saying, like my circuit was perfect. But I am telling you, that LED is always on, without a load...
Thank you audioguru, I am closer now. I figured out, that I turned Q3 backwards. But still, it doesn't work perfect. At current adjustment pot turned to lowest value, LED is not on. It turns on somewhere on the end of turn of current adjustment pot.audioguru said:I know that your circuit works wrong. I explained how it is supposed to work so you can fix it.
1) U3 works wrong so double-check that its inputs are not connected backwards or shorted together.
2) Make sure that the output pin 6 of U3 is not shorted to ground or to -1.3V. What is the voltage of pin 6?
3) Make sure that pin 7 of U3 is about +24VDC.
4) Try replacing U3.
