audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
It is normal for the current regulation to be turned on without U1 in place.
Yes.ClemensA said:So you mean I should change the 2n2219 to a bd139 with heatsink?
in the latest version, the output of U3 drives D9 to reduce the output voltage to zero when the output is shorted. D9 has a forward voltage drop of about 0.7V so the output of U3 must be able to go a little below -0.7V. I used two diodes to make the negative supply for U3 at about -1.3V.Hello audioguru , What is the role of negative voltage? Why negative voltage to as low as-1.3V, or so could use a 3V zener diode instead
Thanks~in the latest version, the output of U3 drives D9 to reduce the output voltage to zero when the output is shorted. D9 has a forward voltage drop of about 0.7V so the output of U3 must be able to go a little below -0.7V. I used two diodes to make the negative supply for U3 at about -1.3V.
A 3V zener diode or even a 5.6V zener diode can be used instead of the two diodes.
For a DC output of 3A, the transformer must supply 4.2A AC. C1 must have enough capacity to filter properly.bg8dmy said:I did a circuit, but found ineffective regulator, for example, in the 3A maximum current range, adjust the voltage of 20V, but the addition immediately after the load into 16V. What is the reason?
My aim is only to check the boards, if they work I'll take the nessessary transformer.The circuit will work with a 22VAC transformer but its max output will be about +28V with no load and about +23V with a 3A load. When you turn the voltage setting pot higher then the output will be full of ripple when there is a load.
I didn't want to use 2N3055 because of the TO-3 package. I'm not familiar with it, and I don't know how to connect it. As I saw the collector is the steel case. So, should the steel case be separated from the heatsink or not, and how to connect it(especially collector)? The BD139's heatsink should be separated from the others one, but should it be separated brom BD's case?The latest version uses 2N3055 transistors in a TO-3 steel case because their max allowed dissipation is 115W each (with a perfect heatsink). Your little TIP3055 transistors are in a plastic TO-220 case and have a max allowed dissipation of only 90W each. So the heatsink for your little transistors might need a fan or a 3rd transistor.
Calculate the thermal resistance needed then look for that number on heatsink spec's.
Q2 is a BD137 or BD139 which is an NPN type, not a BD138 which is a completely different PNP type. It is on its own medium size heatsink. Calculate the thermal resistance needed for its heatsink.
Mounting kits are sold for TO-3 or for TO-220. Mica insulators are also sold for both.I didn't want to use 2N3055 because of the TO-3 package. I'm not familiar with it, and I don't know how to connect it. As I saw the collector is the steel case. So, should the steel case be separated from the heatsink or not, and how to connect it(especially collector)? The BD139's heatsink should be separated from the others one, but should it be separated brom BD's case?
helloHere is my schematic and parts list for the 3A project again:
