P2 is connected ok. When P2 is at it's minimum, the voltage on pin 3 of U3 is 15.05mV, at it's maximum it's 2.07V. Is that normal? At P2 minimum, the voltage on pin 2 of U3 is 45.5mV, at it's maximum is 95.5mV. So there is voltage drop on R7 in any case. Why is that?audioguru said:Hi Fikic,
With no load on the project, the output pin 6 of U3 should always be high at about +24V to +28V. So it does not reduce the output voltage through D9 and it does not turn on Q3 to light the LED.
The slider of the current adjusting pot P2 applies a small positive voltage to the (+) input pin 3 of U3. The voltage should be +0.005V when P2 is turned to minimum and should be +1.414V when P2 is turned to maximum. Without a load, there is no voltage across R7 so the (-) input pin 2 is 0V. Then the output pin 6 of U3 should be always be high.
What range of voltage at pin 3 of U3 do you measure when P2 is turned from minimum to maximum?
Maybe the terminals of P2 are connected wrong.
Maybe U3 is defective. Replace it.
PS.: Is normal, that when I connect a load on PSU, just Q4 and Q5 get warm, Q2 is like nothing is on it..
