0-30V Stabilized Power Supply
Status
Not open for further replies.
morpheous87
Jan 1, 2011
57
This is PicMaster's PCB. I have a question about the PDF. The white print on page 3 and the PCB connection on page 6 aren't same. The parts names and their places are different. I think the white print on page 3 is the correct one, but am I right?
EL_power_supply.pdf
  • EL_power_supply.pdf
audioguru2
Apr 6, 2004
12,026
I hate the confusion caused when somebody takes an existing circuit then changes all the parts designation numbers.
I don't know which one is correct and don't have time to sort it out. Ask Picmaster.
morpheous87
Jan 1, 2011
57
For what purpuse are the 3 trimpots? For what ajustments? And is there a way for fine ajustment of the Voltage and Current.
PicMaster
Feb 18, 2009
90
I will look into it and let you know, Your the first one to spot it.
audioguru2
Apr 6, 2004
12,026
The trimpot beween pin 1 and pin 5 of U2 nulls its input offset voltage. With the voltage set to 0V then the trimpot is adjusted for ezactly 0.0V.
With the output voltage set to maximum then the voltage calibration trimpot is set to 30.0V.
With a 3A load and the current regulation set to maximum the current regulation calibration trimpot is set to 3.0A.
I didn't compare PicMaster's schematic to mine because it might have the trimpots with different values and in different locations.
I think using coarse and fine adjustment pots will be a nuisance. one pot will always be adjusted wrong.
Simply use a big knob on the pot that is about 5cm in diameter.
morpheous87
Jan 1, 2011
57
I did the schematic, and it works fine. Now I'm going to make another one with aim to make +/- power supply. What I have to do for that, should changes have to be made on the board?
audioguru2
Apr 6, 2004
12,026
To make a negative power supply you make the project and use the + output as ground and use the GND output as the negative output. Its transformer must be completely separate from the positive supply project transformer but they can use a single transformer with two completely separate windings.
fikic
Apr 9, 2009
87
audioguru, I mounted transistors on heatsink and tryed PSU. I shorted its output and measure current. At voltage set to 30V and current regulation pot set to highest value, I calibrated it to max current 3A. But when I get near the minimum setting of current adjustment pot, it took about 5-10A. I quickly powered it off to prevent any damage. Why is that? Current regulation doesn't work fine. At highest value of current adjustment pot, I measured 3A, then I was slowly turning it down. Current was always not less than 2,96A at same voltage (30V). But when I got near minimum, LED turned on and that happend (5-10V). What could be wrong with my current regulation?
PS.: I forgot to mention, that I used 25k for RV2 instead of 20k...does this makes any difference?
PPS.: We talked about D8, if you remember. I used BZX85C instead of BZX79C and you said that BZX85C regulates porely. I don't have BZX79C, but I have BZX55C. Can I use it?
PPPS.: Is it possible, that one of D7 diodes in series is faulted, becouse voltage drop across theese two is just 400mv..(they are not shorted, I checked)...
audioguru2
Apr 6, 2004
12,026
Hi Fikic,
In order for the current regulator to limit the current when the output is shorted then the anode of D9 must go very close to ground which causes the output voltage to be very close to ground which limits the current.
Then the output of U3 must go down to about -0.7V. A TLE2141 or MC34071 opamp was selected for U2 because it has an output that goes down almost to ground and has inputs that work at ground. If one of these opamps is used for U3 then a negative supply for it of only -1.3V is fine. But if an ordinary opamp is used for U3 then it needs about -5.6V for its negative supply and the 10V zener that feeds it its positive voltage might need to be changed to a higher voltage.
Did you not use a TLE2141 or MC34071 opamp for U3?
Is your negative supply not working at -1.3V?
fikic
Apr 9, 2009
87
Please look at my post again, I edited it and you replied faster..
stelsing
Feb 1, 2011
7
Good evening. I have collected your scheme, voltage regulation is working well, up to 25 volts regulated (24 volt transformer). But the current regulation does not work at all. In fire diode current limit on the output of 5 volts and the current order of 20 mA. removing the current limit mode, the output from the power supply to 12 amps ...
Tell me what could be and how to configure the boundary current. Podstroichnye resistors do not change anything from the current output. I have a resistor to 20k U2 set the maximum output voltage. But when you switch current limit voltage below 5 volts drop failed. Thank you for your help.
audioguru2
Apr 6, 2004
12,026
The LED is supposed to turn on when the current regulation is beginning to reduce the output voltage.
If it is calibrated to begin current regulation when the output current is 3.0A then its should begin current regulation at less output current when the current adjustment pot is turned down.
When the current adjustment pot is turned down to minimum Then the output current should be no more than a few mA.
Did you always have the voltage set to 30V? Then if you have a 10 ohm load for 3A at 30V, the output voltage should drop to 1.0V when the load is 0.33 ohms.
Maybe you have the terminals of the pots connected backwards.
No.
Didn't you look at its datasheet? It is tested at 5mA like the BZX79C so it is perfect.
Something is wrong with your -1.3V supply. Each diode should have a voltage of 0.65V to 0.7V so their total is supposed to be -1.3V to -1.4V. That is the cause of your problem.
fikic
Apr 9, 2009
87
Ok, I replaced D7 (two diodes) and it doesn't make any difference, so this is not the case. Diodes are fine. Voltage drop across both of them is just about 400mV.  ???
Can you pleeeeease take a look at my schematic and PCB, becouse I don't see any mistake now..please..
dokumentacija.zip
  • dokumentacija.zip
audioguru2
Apr 6, 2004
12,026
Hi Fikic,
Your schematic is correct. Your pcb is an Eagle file that I cannot open because I do not use Eagle.
Check the values of R2, R3, C2 and C3. Replace diodes D5 and D6.
fikic
Apr 9, 2009
87
audioguru said:
Hi Fikic,
PCB is not Eagle, it's Kicad..I will send you pdf..
fikic
Apr 9, 2009
87
@audioguru, thank you for all of your help. I replaced D5 and D6 and PSU works perfect! Current regulation works and everything is fine! Thank you hundred times for your help. :-*
morpheous87
Jan 1, 2011
57
Are there some safety measures for shortening the +/- outputs of the PSU? Also where is apropriate to put a fuse before the regulator and how much A to be? And one more question. The Voltage regulator is working perfect. The current regulator also work, but when the potenciometer is nearly at the beggining (few mAs) the current limit led lit and the voltage goes to almost 0V ( with 15-16V regulated for example). So is there something wrong with the current regulator or it's normal?
adyhansolo
Dec 26, 2008
7
Hi, I need your help.
I built this project (last version with MC34071). I tried to run the power supply in this morning. I measured the input voltage before insert the op amps in the sockets. The AC voltage was 30V, but the DC voltage was more than 50V, about 55Vdc.
I used two caps 6800uF/63V in parallel. I changed them with one 15000uF, but no modification. I measured with , two different digital multimeters with the same value. What is wrong?
Please help and excuse my english.
audioguru2
Apr 6, 2004
12,026
Are there some safety measures for shorting the +/- outputs of the PSU?
If the output is shorted then the current regulator limits the current to its setting. all the parts should be rated and cooled so they do not get too hot.
the fuse should be in series with the high voltage power on/off switch. Use a slow-blow fuse rated for a draw of 150W.
Your opamp U3 has a high input offset voltage. Null it with a pot (like at U2) or increase the value of R17.
Status
