It draws 5A at 12V when hot and it draws maybe 50A when cold.Load - car 60 watt lamp.
audioguru said:But what about if you want to charge a batterry with thats say for example 12 Volts and 2.5 amps....when battery draws 5 amps...and you want to limit the current for a beater charging...when the gurrent limiter is activated...you cant regulate the voltage to 12 volts....
The moment that you connect it then it will try to draw 50A but the current-regulation will limit its current to only 3A by limiting or reducing the voltage.
If you turn the current-setting to maximum and the voltage to zero, connect the light bulb then slowly turn up the voltage it should work up to maybe 10V at 3A.
Your video shows that the warning LED lights when there is no load and the current-setting pot is turned down which is wrong. It is due to an input offset voltage of U3. Increase the value of R17 (it is now 33 ohms) to maybe 47 ohms or 68 ohms until the LED does not light when the current-setting pot is at minimum.
Set the voltage to 13.8V to 14.4V and set the current to 2.5A if you want. The current regulation will reduce the voltage to whatever the battery needs when it draws 2.5A. The voltage will slowly rise as the battery charges and the current will stay at 2.5a until the battery becomes near fully charged when the battery will reduce the current.But what about if you want to charge a batterry with thats say for example 12 Volts and 2.5 amps....when battery draws 5 amps...and you want to limit the current for a beater charging...when the gurrent limiter is activated...you cant regulate the voltage to 12 volts....
Many things will cause the output to always be 0V.4017555 said:i draw this circuit with Orcad 16.3 & multisim 11 But Output is 0v !! why ??
Thanks for answer .audioguru said:Many things will cause the output to always be 0V.
Post a PNG file of your schematic so I can see if something is wrong.
Maybe your SIM software does not know the details of the special opamps that are used in the fixed version.
You have sketched part of tthe original schematic but transistor Q3 is missing. It drives an LED that warns when the current regulator is reducing the output voltage. The current regulator does not do anything when there is no load so it is not reducing the output voltage.4017555 said:I cant use Rv1 Pot because Orcad TL081 Not supported !
I don't have Multisim so I can't see your schematic.Hi audioguru .
I Create this New circuit with Multisim 11 But Not Work !!
My Multisim Save file Attached . Please Help Me ...
Your Multisim schematic is a nightmare of crossed wires going all over the place. You changed all the parts designation numbers so it is too time-consuming to see if anything is wrong.Thanks PNG Attached
They have the transformer short-circuited to the output 0V which is wrong.maciek1234 said:simulation jpg
