Make two completely separate projects (with separate transformers or separate transformer windings).donr said:One more question. Is there a way I can get +/- outputs on this supply. I am going to build it anyway but would be even more handy for me if I had both.
U3 has a load of only 3mA through R20. There is no current in D9. Therefore U3 will not get warm.madafakamw said:Hi again.
I've just finished the PSu work and I got some problems. U3 gets instantly very very hot after i plug it in. Also The current control potentiometer acts like voltage regulator and it regulates between 15 and 38 V. I really need some help.
Your 28V AC transformer might produce 30VAC when it has low load current. 30V AC produces 42.4V peak. The rectifier bridge reduces it to 41.0VDC. Your 45V is a little too high but is OK for opamp U3 if the 10V zener diode that feeds it is not connected backwards. The cathode of the zener diode is marked with a black bar and must be connected to the positive supply. Then the positive supply pin 7 of the opamp will be +31V which is well below its maximum allowed voltage of 44V. Yours might be +35V which is also fine.madafakamw said:Is normal to have 45V at the + and - of the bridge diode? ???
LE:
I use 28V ac transformer.
If P2 shortcuts Pin3 of U3 with R18=U3 gets very hot;
if P2 shortcuts Pin3 of U3 with R17=U2 gets very hot, led also turns on;
I don't know too much electronics and I need someone to help me troubleshoot this power source. I've spent too many hours just to throw it away.
You made the 5A version of the latest circuit. The transformer must be 28V at least 200VA and the heatsink for the output transistors must be huge and maybe have a cooling fan.denci said:So i have build the power supply and i replaced sense resitor to 0.27E and i used three paralleled 2n3055 transistor with 0.33E emitor resistor.
I was thinking about max. current, how can i test this most easily??
Other component are unchanged against VER2 of circuit and REV3 of component!
So i must insert 1k pot in series with existing trim pot and adjustale pin combine together??audioguru said:I think a large knob should be used for adjusting the voltage so you can see where it is and adjust it fine or coarse.
If you add a fine adjustment pot in series with the coarse adjusting pot then one pot will frequently be at its end.
No.denci said:So i must insert 1k pot in series with existing trim pot and adjustale pin combine together??
