audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
I am glad to help you but I am not a SIR, instead I am just an ordinary cool dude.vendaf said:ok sir,, thank you!
I think a SIR was knighted by the Queen of England.
The latest schematic and parts list are here:View attachment 41759mroy559 said:Audioguru, have you got a copy of the last components list while using alternate chips. I apparently remember most of revisions were being in reddish.
R5 is 10k ohms and has only 5.6VDC across it. Then its dissipation is only (5.6V squared/10k=) 0.003W which is nothing and it will not be warm.lu2dlt said:R5 and D5 heat slightly appreciate your help, greetings from Argentina![]()
The datasheet for the MC34071 opamp shows its 10k ohms input offset voltage trimpot connected to pin 1, pin 5 and the negative supply almost the same as a TL081 opamp. View attachment 41761rosana said:hi from brazil!
i didnt understand witch connection i have to do with the legs of the trimpot witch the u2 (i am using the mc4071) and it doesn t have the connection like the tl081 ...number 1 and 5 ...sorry for my english and simple problem with electronic... thanks
Why is that unusual?dcy said:Good Day!
I assembled the original schematic.My problem is that the rectifier out turns to be more than 24V, around50V (unusual because the secondary output of transformer I had is 24V
is this the updated shematic and partlist sir? thank you..redwire said:We seem to have lost the extensive discussion on this power supply topic. I attached what I believe is the latest version. I could not find the updated parts lists to attach.
UPDATE 12/30/09 Added parts list and Eagle file for double sided board (Shown in photo below)
There are only two variable resistors, the same as in the original version:plouf said:furthermore does exist any info of what all these (5 variable resistors) do in the final version ?
