0-30V Stabilized Power Supply
Status
Not open for further replies.
denci
Apr 30, 2012
86
denci said:
I have onother question, i don't know exactly where is the negative power supply in the schematic of stabilized power supply?
Therefore which connection in circuit should i use to negative set voltage (oV to -30V)?
Can anyone help me about this??
audioguru2
Apr 6, 2004
12,026
Some of the circuit uses a -1.3V negative supply. It is made from a few parts.
The entire circuit can have an output of 0V to -30V if you connect its + and - outputs in reverse so that the +30V output is used as ground and the 0V output is used as 0V to -30V.
Many people have built two of this project so that the first one has a 0V to +30V output and the second one has a 0V to -30V output. Each project must have its own power transformer.
vendaf
Jul 26, 2012
9
Can i replace MC34071 to AD711??? or TLE2141 to AD829???,, cause electronic stores here don't have those components.
audioguru2
Apr 6, 2004
12,026
I selected MC34071 or TLE2141 opamps because their inputs work at their negative supply voltage (0V here) and their outputs go down close to their negative supply voltage, and they are available almost everywhere.
The first opamp you guessed about will not work.
I didn't bother looking at the second opamp you guessed about.
ajax007
Aug 4, 2012
7
hi every one. i create the original version and work fine
but i have 2.5A at 30v when turn voltage volume under
7v current get to 1,5 A and overload protection
do not work
please help me
excuse me for poor english
audioguru2
Apr 6, 2004
12,026
do not work
please help me
The original version has many errors that cause it to be unreliable and not meet its specs.
thenr.
Apr 14, 2012
7
do not work
please help me
Hi Ajax007, forget the original version. You should see the xristost's schematic the following link:
http://diyfan.blogspot.com.br/2012/02/adjustable-lab-power-supply.html
ajax007
Aug 4, 2012
7
thank you for reply
my circuit work fine only problem is current not constant. when current volume is max: 30v 3A (short circuit) when current volume ismax and voltage volume is 7v current :2A (short circuit)my transformer is 24v 3A
please help me i dont have new component to create new version .
audioguru2
Apr 6, 2004
12,026
When the original circuit has a 24VAC/3A transformer then the transformer can supply 24V x 3A= 72VA. But 24V rectified produces 24V x 1.414V (-2V for the rectifier bridge) which is +32V.
But the circuit needs at least 40VDC instead of only 32V so the voltage from the original transformer is also too low. The transformer must be rated at 42V x 3A= 127VA.
The tiny old 2N2219 driver transistor gets too hot when the output voltage is low and the current is high. The improved circuit uses a modern power transistor with a real heatsink.
The single 2N3055 output transistor also gets too hot. The improved circuit uses two output transistors (with emitter resistors) to share the heat.
When your output is 7V at 2A then maybe the driver and/or output transistor gets too hot and fails.
ajax007
Aug 4, 2012
7
2N2219 and 2n3055 temperature is normali test circuit this way:1-turn current and voltage(30v) volume max2-connect ammeter and read 3.2A3-turn voltage volume to 30 to 8v connect ammeter and read 3.2A4-turn voltage volume to 7v  connect ammeter and read 2.6A5-turn voltage volume to 3v  connect ammeter and read 1.5Ayou think transformer voltage is low i test 28v and i get same result
thank you
audioguru2
Apr 6, 2004
12,026
With a +32VDC supply and a 3A load, the voltage across R7 reduces the output voltage 1.41V.
The maximum output of the TL081 opamp U2 is +29.1V but it could be as low as +27.6V.
The maximum output of the 2N2219 driver transistor Q2 is +28.1V but it could be as low as +26.3V.
The maximum output of the 2N3055 output transistor is +27.1V but it could be as low as +24.8V.
But the overloaded transformer probably cannot produce rectified 32VDC so the output voltage will probably be less and be unregulated with a lot of ripple.
thenr.
Apr 14, 2012
7
I'm making my power supply 0-30V inside an old ATX power supply, and I have 2 Fans. How should I select the side of the flow?
Should I make throwing air at the heatsink or throwing the air which is inside the power supply out?
Sorry about my poor english.
audioguru2
Apr 6, 2004
12,026
One fan can blow cool air into the heatsink and the second fan can blow hot air out.
We don't know if the fans can cool the output transistor well enough.
That is why the improved version of this project has TWO output transistors to share the heat.
thenr.
Apr 14, 2012
7
Thanks audioguru, I read the answers about to use two 2n3055. Will one BD139 be able to support both tranzistors ?
audioguru2
Apr 6, 2004
12,026
Yes because each output transistor has half the total current then their current gain is higher so the BD139 driver uses less current and is cooler. Even the opamp that drives the BD139 will use less output current and will be cooler.
thenr.
Apr 14, 2012
7
OK Thank you audioguru... When the PS is finished I post the results here.
vendaf
Jul 26, 2012
9
i have a problem about my voltage adjust(potentiometer), the problem is that the voltage is not balance and not linear, my minimum voltage is 0.7v and max with 32v, but if i adjust the potentiometer 1/2 the voltage is only 1.3v, in 3/4 of my potentiometer i can adjust the voltage properly start by 3v-32v but i really wonder why the voltage is gather in the 3/4 of my potentiometer???? i use 10k pot, i already replace it 3x,, but the same thing happened., i also replaced it with 1k value, but the max voltage lower, only 7.4v,,.. can you help me sir???thank you!!
audioguru2
Apr 6, 2004
12,026
The pot is supposed to be a linear pot. You are probably using a pot with a logarithmic audio taper (used as a volume control).
A pot with an audio taper has an output level of about 1/10th or 1/20th when it is half-way.
red baron
Jun 26, 2012
16
Hi Audioguru
I have had a lot of trouble sourcing the shunt resistor (0R27 ohm) for the 5A version in Australia, nearest is 0R22, 10W, or 0R33 10W.
But in the process I think I have ordered the wrong digital voltmeters (0 - 99V 3 wire) for the current display.  Since the volt drop across the shunt will only be just over 1V at 5A it will hardly register, and at 100mA, no chance.
Any ideas how I can fix the display problem?  And can I use the 0R33 shunt resistor?
Status
