electronicslab said:
Yes,the transformer must be changed with 24V ,3-4A .
Now , the maxim output is 18,6V , 1.85A .
Sorry, I made a mistake. I thought your tiny transformer was rated for 1.2W but instead it is rated at 1.2A. Then its maximum power is 18V x 1.2A= 21.6VA.
Its peak voltage is 18V x 1.414= 25.5V so it is overloaded when your output current is more than 21.6VA/25.5V= 0.85A.
The original circuit uses TL081 opamps that have a maximum allowed total supply of only 36VDC.
a 24V transformer might produce 25V with a low current load so its peak voltage is 25V x 1.414= 35.4V and the rectifier bridge reduces it to 34.0V which will be the positive supply to the opamps. But the circuit also supplies a negative 5.6V to the opamps then their total supply is 34.0V + 5.6V= 40.6V which is higher than their maximum allowed voltage.
A 24V transformer is too low for this project anyway. Then the maximum output at 3A will be only about 25VDC, not 30VDC.
My fixed version of this project uses a 28V or 30V transformer and opamps that have a maximum total supply rating of 44VDC. They work with a negative supply of zero or -1.3VDC.
