audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
The project can regulate the voltage if the current pot is set to a higher current than the current that is used, or it can regulate the current (by reducing the voltage). It cannot regulate voltage and current at the same time.Question said:Just tried a 12V motor, which was used in a rechargeable mini vacuum cleaner as a load. That is strange, it uses about 0,5V, no matter if voltage potentiometer is on MIN or MAX, but the speed is changed, when the higher current is set with P2. At the half value of P2 the current rises to 5A and higher (I do not set current pot to the maximum). Just do not know, what is the best to use as a load...
Its MAXIMUM output current is supposed to be only 3.0A, and when the current pot is at half then the MAXIMUM current is supposed to be 1.50A, not 5A.
