0-30V Stabilized Power Supply
Status
Not open for further replies.
audioguru2
Apr 6, 2004
12,026
nida said:
I have replaced two 1N4148 diodes still it gives the same voltage.
Then the diodes are connected backwards or are burned out again.
12000uF capacitor is not available here, so can i connect C1(10,000uF   63V) with a capacitor(1000uF 50V)?
It will not make much difference since the total is only 10% higher.
I bought 0.47ohm resistor but (10W0ohm47) is written on that and it is giving 0.9ohm resistance so can I connect these two resistors in parallel combination? power rating of both resistors is 10W.
You are probably measuring the resistance of the wires on your multimeter. The 0.47 ohm resistor value is probably correct.
I don't need 30V at output, 26V with 3A is enough for my project so still Do I need to replace my transformer?
Then if your 24VAC transformer can deliver 4.24A AC (102VA) it will be fine.
This and nearly ALL modern circuits probably will not work when built on a breadboard. A pcb is needed.
Guber1
Hi, I have built the original circuit placed on the web page and at first it works ok, but the other day I turned it on and suddenly it smell burned, after that the output is always 34V for every position of the potentiometer, later i have seen this post and read about all the udpates make to the original circuit, now i don't if the original circuit has some mistakes and how to fix it, because now with the board already made I have to change a lot of things.
Thanks.
audioguru2
Apr 6, 2004
12,026
The original circuit has many parts overloaded. Then the parts will fail soon.
The transformer voltage and current are too low. Then the output will not be as high as 30V at 3A.
The modified circuit corrected all the problems.
Big zee
Hi there
I tride to do it 4 times
On 4 pcb but the dc gives me 33 volt
And the transformer 25.1 volt and 1.1 amp
The 3rd tl081 gets hot and i hear some thing then i unblog it
After tring that agin its sems fine but the volt still 33 volt
And p1 and p2 and rv1 dosent chang the volt just the LED
All the parts are correct and there are no shorts at all
Is thes fake or what ?
Thx.
audioguru2
Apr 6, 2004
12,026
Big zee said:
Hi there
Since you are using TL081 opamps and a 25V transformer then I guess you made the original project that has problems:
1) Your transformer is probably 27V with no load then its peak voltage is 27V x 1.414= 38.2V and the bridge rectifier reduces it to 36.8V as the positive unregulated supply to the opamps. The opamps also have a negative 5.6V supply so the opamps are powered with a total of 36.8V + 5.6v= 42.4V. But their absolute maximum allowed total supply is only 36V so they fail soon.
2) Many parts in the original project are overloaded and fail soon.
I fixed the project as shown on many threads about it in the forum by using opamps that are rated for a 44V total supply and reducing the negative supply to -1.3V.
Since your output is always 33V then maybe opamp U2 is destroyed by having a supply that is too high or the pins on the driver transistor or the output transistors (yes, the improved circuit users two output transistors to share the heat) are connected backwards so that the transistor that is connected wrong is simply a 5V zener diode from the positive supply voltage that is reducing the 38V to 33V.
Big zee
yes i did the original
and no one says any thing in the original about the problems
so
how can i  fix it
where is the last update
thx.
Big zee
sorry ididnt see the attacted files on my ipad
so can i use the origina PCB
audioguru2
Apr 6, 2004
12,026
The original project is an old kit. DO NOT BUY THE KIT!
so how can i  fix it
Look in the list of topics in the forum for Projects Q/A for two or three threads about the fixed version.
can i use the original PCB?
Many parts are larger (so they do not overheat) and some wiring is different.
Many people posted a revised pcb design in the forum.
Here is the latest schematic and parts list:View attachment 41857
N
nida
Hi, I have build my PCB.I checked the circuit without load so I get 30V at the output.
I have full wave transformer not centre tape 24VAC,5A.(Does it affect the circuit?)
What is current limiting and how it works in this circuit?
I have connected a load of 100ohms 10W so i get 23V and 0.23A at output so Is it correct?
I get 11.8V at the output of U2 and 28.2V at the output of U3.
what voltages should be maintain at the inputs of ICS (U1,U2 and U3)?
Waiting for your reply...
audioguru2
Apr 6, 2004
12,026
The transformer must be 28V or 30V for the output to be regulated at 30VDC.
At 3A your output will be about 26V and will not be regulated because it will be full of ripple because the voltage from your transformer is too low.
The circuit does not have simple current limiting. Instead it has accurate current regulation.
R7 senses the load current and feeds the sense voltage to the (-) input of opamp U3. The current setting pot P2 sends its voltage to the (+) input of U3. Then U3 amplifies the difference to turn on Q3 and the LED to indicate that current regulation is reducing the output voltage through D9. The output voltage is reduced to the amount that accurately produces the current set by the current-setting pot.
only if the output voltage is set to 23V and the current-setting is set higher than 0.23A, or if the voltage is set higher than 23V and the current-setting is at 0.23A.
U2, the driver transistor and the output transistors have a voltage gain of R12/R11 (plus one) that is changed a little by the voltage calibration pot. They amplify the 0V to 11.2V from the voltage setting pot up to 30.0V so the voltage gain should be 2.67857 times.
Big zee
is it this one
http://www.electronics-lab.com/forum/index.php?topic=19066.msg99922#msg99922
thanx alot  :)
audioguru2
Apr 6, 2004
12,026
Big zee said:
is it this one
Picmaster, Redwire and a few other people designed the pcb for the improved version of this project.
jayjaymuller
I'm new to the forum and also looking for the revised printout of the PCB. Can someone please post a link to this.
Thanks.
nitro199
Aug 26, 2012
3
jayjaymuller said:
Thanks.
if you are unable to find the pcb you will be unable to make it also, use search read at least 20 last pages then you will now what issues can ocure in making progress
Big zee
i couldn't find tle2141 or mc34071  :-[
is there other options ?
thx
audioguru2
Apr 6, 2004
12,026
The TLE2141 is made by Texas Instruments who is the largest semiconductor manufacturer in the world.
The MC34071 is made by Motorola/Freescale Semi who is also a very large semiconductor manufacturer.
They were chosen because their maximum total allowed supply is 44V and they have inputs that work at very low voltages so the negative supply voltage can be only -1.3V.
Go to www.farnell.com and click on the flag of your country because they supply electronic parts all over the world.
Big zee
im working on the new one but i already did the old one 4 times can i still use the old one if i used lower volt like 20
audioguru2
Apr 6, 2004
12,026
The calculations are simple:
A 20VAC transformer might produce 22VAC without a load. Its peak voltage will be 22V x 1.414= 31V and the bridge rectifier will charge the positive main filter capacitor to +29.6V.
The TL081 opamps have a maximum allowed total supply of 36V and they still need the negative -5.6V supply so their total supply will be 35.6V which is fine.
The tiny old 2N2219 driver transistor will probably still overheat especially when its obsolete heatsink might not still be available. The pins and heatsink for a modern BD139 driver transistor will not fit on the original pcb.
You can calculate how big the heatsink and fan for a single 2N3055 must be since its maximum dissipation will be very high at 79W.
Status
