audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
I am glad you fixed your circuit but I do not understand why the offset voltage was as high as -0.3V and it could not be nulled with the offset adjust trimpot.
A 24VAC transformer produces 24VAC with its rated load. It might be 25V or 26V with no load.78L05 said:Maybe the problem is too high transformer voltage, but I built this circuit before three-four years and I could set offset voltage at 0.0V without problems. Transformer SEC is 24V, but in my place voltage is about 235V AC, so I get 26V AC on transformer output.
can you attached the PCB please78L05 said:I said that I made my own PCB, and changed few components.
For example, instead of 2N2219 I put BD139 (on heatsink), and for output transistors I use 3xTIP35C with emiter resistors.
why is that ?KevinIV said:The power supply draws an enormous amont of current. Voltage regulators have line and load reguation. It's a great 30V supply. Haven't built it yet.
Naw no way. Tell um.
No.KevinIV said:The power supply draws an enormous amont of current.
Yes, but the math is simple:KevinIV said:I was thinking of the low current IC's in regard to the high current output. Higher current means a lower beta
The modified project has perfect stability, why change it?KevinIV said:I would want to increase the stability of the supply for small signal regulation.
Then you have removed opamp U2 that provides very accurate voltage regulation when the load changes and have removed the adjustability of the output voltage and current.Before and in series with Q2 could be a fully biased NPN transistor so that the bias resistors can set the base voltage. Q2 would only need a BE diode to help limit the voltage drop and a VCE zener diode with a voltage best for average use.
Where is the diode? The output stage has an opamp driving transistors configured as a darlington emitter-follower. The extremely high open-loop gain of the opamp causes this amplifier to be very accurate and have an extremely low output impedance.KevinIV said:A higher conduction voltage diode has a high impedance
No......So there is no small signal regulation.
The LED lights to warn you that current regulation (constant current) is reducing the output voltage.Question said:Hi, does that 'short circuit' LED should be called CV (constant voltage) or CC (constant current)?
