Kevin Weddle
- Feb 23, 2004
- 1,620
- Joined
- Feb 23, 2004
- Messages
- 1,620
I was looking to modify Q2 with a BE diode and a VCE zener and an upstream transistor to drop the voltage for the zener. If Q2 has a low BE operating voltage and the parallel diode doesn't go low impedance, U2 will work fine. It's good to hold Q2 at a constant VCE and VBE. As long as the parallel diode doesn't lose impedance, Q2 can supply adequate current to function Q4 and small signal regulation will only be lost under higher current. But all is not lost if you don't exceed the maximum of U2. The voltage will only follow the small signal.
