My first experiment was to connect the ground of my scope to the ground of my circuit and the probe to the output of the circuit. ie the positive of the LED. Well I didnt even get that far as after connecting the ground of the scope to the ground of the circuit the led simply lit continuously.I realised at this point I do not know what I am doing
so I thought I would video the circuit, working for you to see.
Hi Chris
I have just found this. Some interesting reading!
http://www.analog.com/static/imported-files/zh/reference_dsgn/ECG_HardwareSpec.pdf
Regards
Justin
Is your circuit floating above ground?
Chris
Hi Chris
How are you feeling,,,,,firstly?
Then ,,,,what do you mean "Is your circuit floating above ground". I don't understand the question?
Your scope's ground lead is connected to Earth Ground via the ground pin on the power cord. Your circuit's ground (- common) is probably not connected to earth until you connect the scope's ground lead to it. Hence it "floats above ground".
Also, take a look at this ......
I have made a few tweaks and as you can see,,,its looks good!
Hope your better
Justin (Just in from the well!,,,,well it is Friday!!)
I have probably jumped ahead when the analogue side needs more adjustment but I am anxious to get a prototype out there to test this heart/pulse counter in the field(pardon the pun!) on a horse.
Justin
