hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
Equivalent for Hynix HY27US08121A
hotwaterwizard replied to arup's topic in Datasheet/Parts requests
Hynix HY27US08121A NAND flash chip Datasheet http://www.hynix.com/datasheet/pdf/flash/HY27(U_S)S(08_16)121A%20Series(Rev1.1).pdf Cross Parts http://www.memotech.co.uk/xref/xrefframe.asp CONFIGURATION 64M X 8 HYNIX HY27US08121A SAMSUNG K9F1208U TOSHIBA TC58DVM92A -
[Needed]: 40816229 IC Datasheet
hotwaterwizard replied to masterleous's topic in Datasheet/Parts requests
TX2 Datasheet Attached Search Results TX-2 40816229 IC Datasheet TX2.pdf -
CA309 HA274 MC3476P1 NTE996 http://www.powerdesigners.com/InfoWeb/design_center/Appnotes_Archive/an6048.pdf http://www.powerdesigners.com/InfoWeb/design_center/Appnotes_Archive/an6077.pdf http://www.ee.washington.edu/stores/DataSheets/linear/ca3080.pdf http://www.till.com/blog/archives/2005/06/last_of_the_ota.html
Not a good number check here http://www.mouser.com/catalog/625/95.pdf
All I can find is M52307
Here is the Datasheet. CD4013BC.pdf
Here are a few links i found on Google. Try it yourself you can find many more. Datasheets http://www.national.com/ds/CD/CD4093BC.pdf http://users.pandora.be/on4ldz/Lightning/data_sheet/CD4093.pdf http://noel.feld.cvut.cz/hw/motorola/books/dl131/pdf/mc14093brev3.pdf Application notes http://online.sfsu.edu/~sfranco/CoursesAndLabs/Labs/453LabsPDF/453Lab3.pdf http://hyperphysics.phy-astr.gsu.edu/HBASE/electronic/schmitt.html http://www.ee.ttu.edu/lab/robot/hyster.htm http://en.wikipedia.org/wiki/Schmitt_trigger http://www.musicfromouterspace.com/analogsynth/mmlogic.html http://www.answers.com/topic/schmitt-trigger
TA8659n is a Jungle IC Here is a Datasheet for a Simular IC. TA8759BN [attachment deleted by admin]
LA4227 Having trouble with the pinout but I was told the Pinout of LA4627 is the same but the specs are different. The specs are here. http://service.semic.sanyo.co.jp/semi/eng/search/property.asp?PROD=LA4227&CLCD=15 LA4227_Data.pdf LA4627.pdf
How about a running message sign
220volts? 220_voltios.zip
I Found this. http://www.cndzz.com/info/2488-1.htm http://www.mculand.com/e/sub2/sam4_app/1_basic_timer.pdf
3 Phase Motor Control TPIC43T02 Datasheet http://focus.ti.com/lit/ds/symlink/tpic43t02.pdf Steper Control http://www.cs.uiowa.edu/~jones/step/circuits.html 3 phase converter http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
I need the CD5954CB datasheet (DVD - DRIVER)
hotwaterwizard replied to Nagi's topic in Datasheet/Parts requests
Hmmm Which one to choose? http://www.crowbusters.com/recipes.htm http://www.thecrowroost.com/RECIPES.htm http://www.cooks.com/rec/search/0,1-0,crow,FF.html http://bertc.com/crow_casserole.htm http://bertc.com/three_crows.htm http://www.idahostatesman.com/apps/pbcs.dll/article?AID=/20041216/IDOUT/412160333/1136/IDOUT Mabe This one? Crow Pie 1 crow stuffing of your choice salt and pepper shortening flour 2 Pie crust mixes 2-3 hard-boiled eggs Stuff the crow. Loosen joints with a knife but do not cut through. Simmer the crow in a stew-pan, with enough water to cover, until nearly tender, then season with salt and pepper. Remove meat from bones and set aside. Prepare pie crusts as directed. (Do not bake) Make a medium thick gravy with flour, shortening, and juices in which the crow has cooked and let cool. Line a pie plate with pie crust and line with slices of hard-boiled egg. Place crow meat on top. Layer gravy over the crow. Place second pie dough crust over top. Bake at 450 degrees for 1/2 hour. -
It is only in the search Database but the Datasheet can not be found. Try downloading it it is not there. http://kazus.info/datasheets/search/go/?query=CD5954CB&nohistory=1&h=1 Nope Nothing there. Sorry to come off so strong but it bothers me when people make comments and say it took a few seconds on Google but, the Datasheet is nowhere to be found. If it is there then I challange you to Upload the Datasheet Here. You will then see me eat crow on my previous comments. -
Page 14 states LM353 = LF358 http://www.elektronka.com/download/doc/tablica_ekvivalenata.pdf DATASHEETS http://www.fairchildsemi.com/ds/LF%2FLF353.pdf http://www.cs.cmu.edu/~RAS/old/DataSheets/LF353.pdf http://www.st.com/stonline/products/literature/ds/2153.pdf
Here is the Datasheet sk100_teamasia.pdf
Looking for Old or Discontinued IC
hotwaterwizard replied to Siberia's topic in Datasheet/Parts requests
you sure it is not sn7416? sn7416.pdf -
IC MN15142TEM Data used in National color tv old model
hotwaterwizard replied to ahshk's topic in Service Manuals
The best I could do is a schematic using this IC [attachment deleted by admin] -
phillips MC-500/37 schematic? Anything!
hotwaterwizard replied to jughead's topic in Service Manuals
Part 2 [attachment deleted by admin] -
Wow what a pain. Lets try this. [attachment deleted by admin] -
Dial electronics has them. http://www.dialelec.com/39.html Tel: (+44) 191-417-7003 Fax: (+44) 191-417-7053 Email: [email protected] Address: Dial Electronics Ltd, Burnhope Road, Washington, Tyne and Wear, England, NE38 8HZ
You can still get the original. At Allied Electronics equivalent 1N1202A
