Jump to content
Electronics-Lab.com Community
Posted
2)About the third Potentiometer (1K), I placed it in series with P1. Can you tell me if it is correct?
When you asked me earlier about P3,  I thought you were referring to point 3 from the original sketch instead of Potentiometer 3.  I don't think I ever labeled it P3, so it was throwing me off.    I don't have the coarse and fine Potentiometers shown on the Eagle PCB file I posted because no additional connections on  the PCB are necessary to use the coarse/fine controls.
Yes you intall P3 in series with P1 but you do not have it installed correctly in your sketch.  On P3  you need to cut the connection between  ground and point 2.  Then connect  pins 1 and 2 together.      I think.
Posted
If only I saw this conversation a few days earlier... :D
Last night I built the PS using schematics and part list from the original version...
I tried to test it: connected voltmeter to the output, then turned it on, led blinked and I saw a voltage on the voltmeter.
But it doesn't matter anymore :)
Now I will make a new project from the latest schematics...
And now I want to ask a lame question about potentiometer. Let's say I use the original version of PS. I'm confused about how to connect the potentiometer (ie. Voltage adj. one) correctly. Pot has 3 pins: ground, the one we take + from pot, and the one we give + to pot.
So is that right to connect the ground one to 5th, middle one to 12th, and the one where we give plus to pot - to 10th?
Posted
Is it possible to modify the link in the original project that points to the lost thread so that it points to this thread?
Besarmatis: I have posted a table comparing parts lists for the original, fixed and 5A versions some days ago in this thread.
Posted
It is possible to do that but we can't do it, only the administrator can.
Posted
effenberg0x0, I saw that table and I appreciate for you comparing parts :)
The only thing left for me is to buy some new parts and the transformer (which is the worst thing, because it costs much).
Someone, please answer my question which i posted before about the pot connection. I need to know if my thoughts are right.
And one more question. I want to build two of these projects to have  2 separate power supplies and if I need, I have a dual polarity one. So the question: Do I need 2 transformers or it is enough to have one but with dual second winding (like 2x30V 2x4A)?
Posted
Hi Besarmatis,
It is easy to see how to connect a pot when you look to see that it is a semi-circular resistance track and a rotating wiper along it. The resistance connects to the end pins and you can see which end is connected to the wiper pin (the middle pin) when the control is turned clockwise then counter-clockwise.
The original version of this project does not have an output of 30VDC at 3A. Its output might go as high as 25V at 3A but might reach 30V at much lower current.
At full power its output is full of ripple.
At full power many parts are overloaded.
Its voltage and current controls try to go too high.
Without a load its opamps have a total supply voltage that is higher than their max allowed voltage.
You can use your transformer if you allow the new version to have reduced max output voltage and current.
If you want to connect two of these power supplies so that one supplies a negative voltage then they need to be completely separate with separate transformers or two separate windings on one transformer.
Posted
Thanks for reply, audioguru,
So were I right saying that one is ground pin and two others are adjustable resistance? And were I right saying which pin should be connected to looking at the original project?
I know that it has to be completely separate power supplies, and the question is: which one is better, to use two transformers or one with double second winding? Or it is doesn't matter?
One more question, maybe someone could suggest some e-shop, where I could buy transformer (230V first winding) with lower price, because in my country (Lithuania), for example, transformer 2x24V 2x3.12A (sec. wind.) costs 50$. So I already bought one, but now I need to buy new one which has more power and I don't have bags of money, so I need to find cheaper ones :(
Posted
Besarmatis, I couldn't find transformers at reasonable prices in the market here too. My solution was to have them built in a small shop that does it on demand. I managed to get two units for half the average price of a single unit in the market. They were built exactly to my specs (core, wire, windings, etc). Mine are 115V/230V - 30V 5A. Maybe you can find a shop like this there?
Also, if you're putting them in parallel, its important that they don't differ much. I have posted some links that explain why.
I would go for two separate transformers, simply because I may want to reuse one of them in a new project in the future (considering trafos are expensive).
Posted
effenberg0x0, if it's not a secret, what was the price of you transformer?
And to be correct, if I want to build the version of the project 0-30V 0-3A, then I need secondary winding 30V and at least 4A?
Any transformer up to 2A is common here and costs an average of US$8.
3A transformers are a little harder to find and were priced at an average of US$15.
4A are WAY hard to find. They were priced at US$30.
5A units were simply nowhere to be found. After searching for an entire week I found only four stores that had them, but prices were beginning at US$100.
I had my 30V/5A units made for US$21 each.
In the latest parts list, a 28V 4.3A, 118VA transformer is mentioned. So if you go for 30V 4.5 or 5A it will be enough.
Posted
OMG how cheap  :'(
I've been searching for shop to make the transformer for me for a few hours, but no luck.
I tried to search for already made trafos and found such: Toroidal mains transformer 160VA 230/30V for 40$.
So for 2 it would be 80$...
It would be perfect, but the price for the student... :D
Well, I'll have to choose whether to eat food or to make a dual polarity power supply... :D
Posted
Redwire said in a previous post that me made his unit using a microwave oven transformer. The unit was 7A or more I think. Actually I almost cried when I read this: If I had searched at repair shops, electronics dump places or even sites like eBay, I would be able to buy a broken microwave oven almost for free. Consider this option. Also think of other appliances that may have a suitable transformer.
Another option would be to buy 2A transformers, if they're cheaper, and put them in parallel.
Posted
No.
The voltage and current setting pots are voltage dividers, not adjustable resistors. The calibration trimpots are adjustable resistors.
Posted
So it the only matter how to connect the end pins of pot is how you want to adjust voltage.
First way: turning clockwise increasing voltage.
Second way: turning clockwise lowering voltage.
Now I understand :)
The middle one stays the same in both ways.
Posted
Earlier today I had requested the admin of the website to update the wrong link at the original project page (it was ponting to a thread that was lost and not to here). It is done now. Maybe other users will read this thread before building the wrong project.
Regards,
Effenberg
Posted
I think that link should be put on the top of the project page, moreover, someone should make new tutorial for building this project. For example you, effenberg0x0, when you done your project :D
Maybe I could make some tutorial after 2 months with pictures and schematics and pcb and periphery like lcd vmeter ameter and automatic cooling system with fans (avr).
Posted
Now I understand :)
Yes.
Trimpots have an arrow marked "CW" that points to the pin that the slider goes toward when the shaft is turned clockwize.
Posted
It will take a while for me besamartis. I have one month to write an essay describing the operation and importance of each component in this circuit, the main individual circuits, possible changes/updates, etc. A lot of it is still not clear to me and I have to study more to get it done. I have it assembled on breadboard and am using multimeter/oscilloscope to analise it. I'll go for the PCB and assembly only by the end of January...
By then, I'll be happy to post all my material here for whoever may benefit from it.
Posted
Of course, leaving fans non stop has it's own pluses: less heat in the case, but it is the most simple way. For us - electronics it is not fun... :D
Sometimes I think, why factories can do better, why cannot I built even more better project, even it is not worth the price, but it is fun...
Posted
I think any decent Power Supply project built correctly will be better than commercial units. I'd say more than 90% of the commercial units I see in the market are cheap things that don't look like they will last 6 months. And, of course, it's always more entertaining to build it, no matter the price and time spent. That's why we're all here for anyway.
For example, one of the features I'd like to add to this project are digital controls instead of potentiometers ("+" and "-" push buttons). Don't know how yet. It's absolutely unnecessary, but it's cool.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
