audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
If the resistance of R7 or its connections is intermittent then opamp U3 will have an input voltage high enough to destroy U3 and reduce the output voltage.
Hi everyonehi James Bond O ,
you may have to indicate the error image and to members.
Otherwise, getting some error message doesn't appear a good way of reporting.
you can capture the screen and upload as .png.
it helps proteous gurus to study and comment.
Yeah, I know. I did the math from the datasheet and given what the simulation is giving me, I'd say the device can probably handle it. I don't have the equipment to lay this out and test in the real world but PD from both amps only total around 300mW and if I'm reading things right, the 2142 can probably handle it.The opamps will be cooler if they are TLE2141 singles.
It is 60Hz from your electricity supply, not oscillation. Maybe you built the defective original circuit that has errors and many overloaded parts? The fixed and improved version is at the beginning of this thread. Maybe the tiny overloaded rectifier diodes failed or the transformer has burnt. The main filter capacitor has a value much too low. The original project cannot produce regulated 30V at 3A but maybe 25V at 3A instead or 30V at 1.5A. The original opamps are operating at a total supply voltage higher than their maximum allowed voltage and are noisy.I've built a power supply using this circuit. I noticed that it is noisy/oscillating when in constant current mode.
I should have provided more information. I built the revised circuit that uses the TLE2141 op amps.It is 60Hz from your electricity supply, not oscillation. Maybe you built the defective original circuit that has errors and many overloaded parts? The fixed and improved version is at the beginning of this thread. Maybe the tiny overloaded rectifier diodes failed or the transformer has burnt. The main filter capacitor has a value much too low. The original project cannot produce regulated 30V at 3A but maybe 25V at 3A instead or 30V at 1.5A. The original opamps are operating at a total supply voltage higher than their maximum allowed voltage and are noisy.
Great job! I'd checked the positive supply and it's ripple was low. I forgot to check the negative supply. The negative supply has a lot of ripple. Now to troubleshoot that problem & get it fixed.You know what? The current regulator opamp is the only one using the -1.3V supply that is half-wave rectified so if C3 is defective or is upside down then it produces 60Hz interference. 'scope the -1.3V supply to see.
