MINIX N304-AI Mini PC Packs Intel Core 3 304 SoC and 24 TOPS AI
A compact Intel Core 3 304 system with 16GB LPDDR5X, 24 TOPS AI performance, dual NVMe expansion, dual Gigabit Ethernet, and triple 4K display support.
MINIX has introduced the N304-AI, a compact mini PC powered by Intel’s Core 3 304 SoC with integrated Intel Graphics and an Intel AI Boost NPU. The system combines 16GB of LPDDR5X memory, dual M.2 NVMe slots, dual Gigabit Ethernet, and triple 4K display support in a compact enclosure.
The Intel Core 3 304 features five cores, including one performance core and four efficiency cores, with a maximum clock speed of 4.3GHz and 6MB of cache. The processor platform provides up to 24 TOPS of combined AI performance, with 15 TOPS from the Intel AI Boost NPU and another 9 TOPS from the integrated graphics.
MINIX N304-AI compact mini PC with Intel Core 3 304 processor.
MINIX N304-AI specifications
  • SoC: Intel Core 3 304 5-core/5-thread (1P + 4 LP-E) processor @ up to 4.3GHz with 6MB cache, Intel Graphics (9 TOPS), and Intel AI Boost NPU (15 TOPS); 15W base power (24 TOPS total AI performance)
  • System Memory: 16GB LPDDR5X-6400 (soldered on board; no expansion slot)
  • Storage
    • 512GB M.2 2280 PCIe 3.0 x4 NVMe SSD pre-installed
    • 1x M.2 2280 PCIe 4.0 x2 NVMe slot
    • 1x M.2 2280 PCIe 4.0 x1 NVMe slot
    • Support for up to 4TB total storage expansion
  • Video Output
    • 1x HDMI 2.1 TMDS port up to 4Kp60
    • 1x DisplayPort 1.4 up to 4Kp60
    • 1x USB 3.2 Gen2 Type-C port with display output up to 4Kp60
    • Support for triple independent displays
  • Audio: 3.5mm audio combo jack, digital audio via HDMI and DisplayPort
  • Networking
    • 2x Gigabit Ethernet RJ45 ports
    • Dual-band 802.11ax Wi-Fi 6 and Bluetooth 5.3 via M.2 2230 module
  • USB
    • 2x USB 3.2 Gen2 Type-A ports
    • 2x USB 2.0 Type-A ports
  • Misc: Power button, reset button, active cooling with internal fan
  • Power Supply
    • 19V / 3.42A (65W max) via 2.5/5.5mm DC input
    • Up to 100W via USB-C PD input
  • Dimensions: 127 x 126.8 x 46 mm
  • Weight: 357.6 grams
On the software side, the MINIX N304-AI comes with 64-bit Windows 11 Pro preinstalled. It supports features such as advanced networking and domain management and can be used with the system’s Intel AI Boost NPU for local AI workloads.
MINIX N304-AI front and rear I/O ports.
We covered MINIX mini PCs like the NEO Z100-0dB, Z100-AERO, Z300-0dB, and Z150-0dB, which use older Intel chips without an NPU. We also covered the larger ER939-AI with AMD Ryzen AI Max+ 395 and up to 126 TOPS. Compared to all of that, the N304-AI uses the same small 127 × 127 × 46 mm design but switches to Intel Core 3 304 with up to 4.3 GHz and 24 TOPS AI performance. It has 16GB LPDDR5X, a 512GB SSD, two extra M.2 slots, dual Gigabit Ethernet, and HDMI, DisplayPort, and USB-C for three 4K displays. Windows 11 Pro is included.
The MINIX N304-AI is listed on the company’s online store for $715 in the configuration with 16GB of LPDDR5X memory and a 512GB SSD. The product is currently marked as “Coming Soon.”
MINIX N304-AI mini PC with its accessories and packaging.
Images used courtesy of MINIX
