ON Semiconductor continues to make battery-less IoT a reality with Bluetooth® Low Energy
https://www.electronics-lab.com/semiconductor-continues-make-battery-less-iot-reality-bluetooth-low-energy/
ON Semiconductor, driving energy efficient innovations, continues to enable battery-less and maintenance-free IoT with the introduction of its RSL10 Multi-Sensor Platform powered solely with a solar cell. This complete solution supports the development of IoT sensors using continuous solar energy harvesting to gather and communicate data through Bluetooth® Low Energy, without the need for batteries […]
Hephaestus – a fully DIY 3D printer
https://www.electronics-lab.com/hephaestus-fully-diy-3d-printer/
Frank documented a 3D printer build, called Hephaestus: I finally did it, I designed and built my own 3D printer. This is in no way “the best 3D printer”. Instead, this was an epic and nightmare project that exercised my ability to engineer and build my own CNC machine. Along the way, I figured out […]
BreadShield – Bridging Arduino to breadboard with no jumper wires
https://www.electronics-lab.com/breadshield-bridging-arduino-breadboard-no-jumper-wires/
BreadShield is a shield that maps Arduino pins to breadboard ties without jumper wires. It inserts into both of them, bridging them together mechanically, electrically, and firmly. Using jumper wires gets messy and tedious Many projects start with connecting an Arduino and a breadboard using jumper wires. But jumper wires can easily become too many […]
10 x 1W White LED Shield For Arduino Uno
https://www.electronics-lab.com/10-x-1w-white-led-shield-arduino-uno/
This project includes 10 LEDs of 1W each, and provides high intensity lighting that can be used in various applications. The board is made in Arduino shield form and can be used with Arduino Uno or Mega. Each LED can be controlled individually connected to digital pins D2-D11 of Arduino. Circuit requires 9-12V supply, it […]
https://www.electronics-lab.com/project/10-x-1w-white-led-shield-arduino-uno/
Bridgetek Joins forces with Zerynth & Riverdi to forge IoT Technology Partnership
https://www.electronics-lab.com/bridgetek-joins-forces-with-zerynth-riverdi-to-forge-iot-technology-partnership/
In order to broaden the appeal of its advanced graphics controller ICs in the emerging Internet of Things (IoT) sector, Bridgetek has entered into a three-way collaborative partnership with IoT development experts Zerynth and advanced display solutions provider Riverdi. Through cooperation between these companies’ engineering teams and drawing on their respective skillsets, customers will be […]
Owon AG1011 10Mhz 1-CH Arbitrary Waveform Generator
https://www.electronics-lab.com/owon-ag1011-10mhz-1-ch-arbitrary-waveform-generator/
OWON multi-function waveform generator, working as arbitrary waveform generator, and function generator 2 in 1 provides stable, accurate, and pure DDS signal sources. Its user-friendly UI, together with keyboard layout brings brand-new user experience into the current market. Features Advanced DDS technology, upto 10MHz frequency output 125MS/s sample rate, and 1μHz frequency resolution Vertical Resolution : […]
Two-Digit Thermometer using ATtiny84 and a DS12B20
https://www.electronics-lab.com/two-digit-thermometer-using-attiny84-ds12b20/
David Johnson-Davies shared another nice tiny project. This time is a two digit thermometer based on ATtiny84 and DS12B20 1-Wire temperature sensor. It uses a DS12B20 1-Wire temperature sensor, and an ATtiny84 to drive the display and read the sensor. It’s just over 25mm square; about the size of a British 50 pence piece. The […]
Owon P4603 1CH 0 – 60V / 0 – 3A 180W DC Power Supply
https://www.electronics-lab.com/owon-p4603-1ch-0-60v-0-3a-180w-dc-power-supply/
OWON P4603 Linear DC power supply newly launched with small body, lighter weight, easier to carry. Single channel, competitive unit price. With high resolution 1mV/1mA, 3.7 inch large TFT LCD display, 180W maximum output power. Low ripple and noise can meet the requirement for high accuracy testing. It can save up to 5 sets of parameters […]
Owon XDS3102 100Mhz 1GS/s Oscilloscope features AWG and datalogger
https://www.electronics-lab.com/owon-xds3102-100mhz-1gs-s-oscilloscope-features-awg-datalogger/
2 channel DSO with 100 MHz bandwidth, 1 GSa/s sample rate, 40 MSa memory depth and VGA interface and 20.3 cm touchdisplay with a resolution of 800 x 600 pixel. The new XDS n-in-1 digital storage oscilloscop of Owon offers reliably measurement technology for a really good price. The colorful 8″ (20.3 cm) TFT LCD […]
