Seeed Studio XIAO STM32C5 Packs CAN FD and Heated 6-Axis IMU
The compact STM32C5A3CG board combines dual CAN FD, 16MB Flash, programmable IMU heating, and battery support for robotics and embedded projects.
Seeed Studio has introduced the Seeed Studio XIAO STM32C5, the first STM32-powered board in its XIAO series. The compact development board features an STM32C5A3CG microcontroller with a 144MHz Arm Cortex-M33 core, 1MB of internal Flash, 256KB of SRAM, and 16MB of external Flash. It also integrates two CAN FD controllers, an onboard six-axis IMU, and USB-C connectivity for embedded development, robotics, and industrial control applications.
The board combines motion sensing and CAN FD communication in a small form factor. Its LSM6DS3TR-C accelerometer and gyroscope work alongside dedicated heating resistors that allow firmware-controlled sensor warm-up. Developers can adjust the heating power through PWM signals and use the IMU’s temperature readings to implement temperature regulation. This approach helps reduce temperature-related sensor drift and improve measurement consistency in robotics and motion-sensing applications.
XIAO STM32C5 front pinout
Key Features of Seeed Studio XIAO STM32C5:
- Processing: STMicroelectronics STM32C5A3CG microcontroller
- 144MHz Arm Cortex-M33 CPU with floating-point unit (FPU) and DSP support
- 1MB program Flash and 256KB SRAM
- 16MB external Flash for data storage
- Communication:
- 2x hardware CAN FD interfaces
- TI TCAN3403-Q1 transceiver for the second CAN FD interface
- CANH/CANL bus connections with onboard 120Ω termination
- USB 2.0 Full-Speed interface (12Mbps) through USB Type-C
- Motion Sensing:
- LSM6DS3TR-C 6-axis inertial measurement unit (IMU)
- 3-axis accelerometer and 3-axis gyroscope
- Built-in sensor heating elements with PWM-based control
- Software-controlled sensor warm-up and temperature compensation
- Peripheral Connectivity:
- UART, I2C, SPI, and ADC
- GPIO pins with 3.3V logic
- SWD debugging interface
- Dedicated CAN FD and battery connections
- Hardware Features:
- 48MHz external high-speed crystal
- Reset and Boot buttons
- User and charging-status LEDs
- Castellated edge pads for PCB integration
- Power Management:
- 5V input through USB Type-C
- 3.7V–4.2V Li-ion/LiPo battery support
- Integrated battery charging and voltage-monitoring circuits
- Dimensions: XIAO form factor (21 × 17.8 mm)
XIAO STM32C5 back pinout
Developers can program the Seeed Studio XIAO STM32C5 using Visual Studio Code and PlatformIO with the Zephyr RTOS framework. Seeed provides a custom PlatformIO platform package for board support. The development process includes creating a project, configuring the required Zephyr files, building the firmware, and uploading it through PlatformIO. The board also comes with a UF2-capable bootloader for firmware updates. Developers can start with a simple LED blinking example before exploring battery-voltage monitoring, IMU data acquisition, and CAN FD communication. More information available on the wiki page.
XIAO STM32C5 CANFD
We have previously covered several XIAO development boards, including the XIAO ESP32C3, XIAO ESP32S3 with Wio-SX1262 LoRa Module, XIAO ESP32C6, and Seeed Studio XIAO 1.47-inch IPS Touch Display, among others. Feel free to check out these products if you’re interested.
The XIAO STM32C5 is available for $16.29 on AliExpress or $9.90 through the Seeed Studio store. Seeed Studio also offers a pre-soldered version for $10.90.
Images used courtesy of Seeed Studio
