STM32H7P Series MCUs Feature 520MHz Cortex-M7 and Neural-ART NPU
STMicroelectronics introduces STM32H7P4 and H7P5 MCUs with hardware signal processing, 85 GOPS AI acceleration, and advanced motor control features.
STMicroelectronics has added another new member to its unified STM32 ecosystem, the STM32H7P – designed for enhanced machine learning performance and with a specialized digital signal processor (DSP) and built with industrial automation systems in the forefront. The STM32H7P builds on the successful STM32H7 series, offering a 520MHz Cortex-M7 core and two dedicated hardware accelerators for 1.7 times the performance of other parts available. The STM32H7P4 and STM32H7P5 are two 520 MHz Arm Cortex-M7 MCUs that belong to the STM32H7P family for digital power, motor control, industrial sensing, and edge AI applications. Both include a Hardware Signal Processor (HSP) to speed up math and signal processing operations, and the STM32H7P5 features an 85 GOPS Neural-ART NPU for Edge AI inference/TinyML.
The MCUs offer up to 2MB dual bank flash, 736KB SRAM, two high resolution timers with up to 24 PWM outputs, three advanced motor control timers and four 12-bit ADCs. Additional features encompass a Tightly-Coupled Memory (TCM) architecture, analog peripherals with analog to digital and digital to analog converters (ADCs and DACs) as well as comparators, timers from the STM32G5 mixed-signal chips, an industrial rating for reliable operation in ambient temperatures up to 125°C (257°F), CORDIC and FMAC math accelerators, three CAN FD interfaces, USB OTG Full-Speed and external memory support via Octo-SPI and FMC interfaces.
STM32H7P4 Cortex M7 MCUs series with Hardware Signal Processor HSP
STMicroelectronics STM32H7P4 and STM32H7P5 Specifications:
  • Processor and Computing Performance:
    • MCU Core: 32-bit Arm Cortex-M7 processor operating at up to 520 MHz
      • Double-precision floating-point unit (FPU)
      • Digital Signal Processing (DSP) instruction set
      • Memory Protection Unit (MPU)
      • 32 KB instruction cache and 32 KB data cache
  • Performance: 2,773 CoreMark (5.33 CoreMark/MHz)
  • Mathematical and Signal Processing Accelerators:
    • Hardware Signal Processor (HSP): Dedicated coprocessor with 32-bit floating-point support for:
      • Matrix and vector computations
      • Fast Fourier Transform (FFT) and Inverse FFT (IFFT)
      • Digital filtering and convolution
    • CORDIC Accelerator: Hardware acceleration for trigonometric and mathematical functions.
    • FMAC: Dedicated Filter Mathematical Accelerator for digital filter operations.
  • AI Acceleration:
    • Neural Processing Unit (STM32H7P5 only): ST Neural-ART NPU operating at up to 520 MHz.
    • AI Performance: Up to 85 GOPS (0.085 TOPS).
  • Memory and Storage:
    • Flash Memory: 1 MB or 2 MB dual-bank flash with Error Correction Code (ECC).
    • SRAM: 736 KB total, comprising:
      • 192 KB Instruction Tightly Coupled Memory (ITCM)
      • 128 KB Data Tightly Coupled Memory (DTCM)
      • 320 KB AXI SRAM
      • 96 KB AHB SRAM
    • Backup SRAM: 4 KB.
    • OTP Memory: 1 KB one-time programmable storage.
    • External Memory Interfaces:
      • Octo-SPI supporting PSRAM, NOR flash, HyperRAM, and HyperFlash at up to 100 MHz.
      • Flexible Memory Controller (FMC) supporting SRAM, PSRAM, NOR/NAND flash, and SDRAM with up to a 16-bit data bus.
  • Connectivity and Peripherals:
    • GPIO: Up to 134 general-purpose I/O pins with interrupt support, including up to 132 5V-tolerant pins.
    • I2C: 3x interfaces with SMBus and PMBus support.
    • I3C: 1x interface.
    • Serial Interfaces:
      • 5x USART, 5x UART, and 1x LPUART
      • 6x SPI interfaces, including 3x supporting full-duplex I2S
    • CAN: 3x CAN FD controllers.
    • USB: 1x USB OTG Full-Speed interface.
    • USB Power Delivery: 2x USB Type-C Power Delivery controllers (UCPD).
    • SD/MMC: 1x SD/SDIO/MMC interface operating at up to 100 MHz.
    • DMA: 2x controllers, comprising High-Performance DMA (HPDMA) and General-Purpose DMA (GPDMA).
  • Analog Interfaces:
    • ADC: 4x 12-bit analog-to-digital converters, supporting up to 5 MSPS and 44 channels.
    • DAC:
      • 1x dual-channel 12-bit DAC with buffered outputs.
      • 3x dual-channel 12-bit DACs dedicated to internal applications.
    • Analog Comparators: 8x comparators.
    • Voltage Reference: Internal reference voltage ranging from 1.8V to 2.9V.
    • Temperature Monitoring: Integrated analog and digital temperature sensors.
    • Audio Processing: 1x digital filter for Pulse-Density Modulation (PDM) microphones.
  • Timers and Motor Control:
    • High-Resolution Timers: 2x HRTIM units with up to 24 PWM outputs and 1.9 ns resolution.
    • Motor Control: 3x 16-bit advanced motor-control timers.
    • General-Purpose Timers:
      • 4x 32-bit timers.
      • 9x 16-bit timers.
      • 2x 16-bit basic timers.
    • Low-Power Timers: 5x 16-bit LPTIM units.
    • Additional Timing Functions: SysTick, Real-Time Clock (RTC), independent watchdog, and window watchdog.
  • Security Features:
    • Readout Protection (ROP) and Proprietary Code Readout Protection (PC-ROP).
    • Active tamper detection and secure firmware upgrade capabilities.
    • Hardware HASH accelerator supporting MD5, SHA-1, SHA-2, and HMAC algorithms.
    • 32-bit True Random Number Generator (TRNG) compliant with NIST SP 800-90B.
    • 96-bit unique device identification number.
  • Clock Management:
    • Internal Oscillators:
      • 64 MHz High-Speed Internal (HSI).
      • 48 MHz HSI48.
      • 4 MHz Clock Internal (CSI).
      • 32 kHz Low-Speed Internal (LSI).
    • External Oscillators:
      • 4–50 MHz High-Speed External (HSE).
      • 32.768 kHz Low-Speed External (LSE).
    • PLL: 3x phase-locked loops with fractional-mode support.
  • Debugging and Development:
    • Serial Wire Debug (SWD) interface.
    • JTAG debugging support.
    • 4 KB embedded trace buffer.
  • Power Management:
    • Operating Voltage: 1.71V to 3.6V.
    • Power Regulation: Integrated Low-Dropout (LDO) regulator or Switched-Mode Power Supply (SMPS) step-down converter, depending on the device variant.
    • Low-Power Modes: Sleep, Stop, Standby, and VBAT.
    • Power Protection: Power-On Reset (POR), Power-Down Reset (PDR), Programmable Voltage Detector (PVD), and Brown-Out Reset (BOR).
    • Backup Power: Battery-backed supply with charging support.
  • Package Options:
    • ECOPACK2-compliant packaging:
      • LQFP100: 14 × 14 mm
      • LQFP128: 14 × 14 mm
      • LQFP144: 20 × 20 mm
      • LQFP176: 24 × 24 mm
      • TFBGA100: 8 × 8 mm
      • UFBGA176+25: 10 × 10 mm
      • Exposed-pad LQFP packages available on selected variants.
  • Operating Temperature: -40°C to +125°C
STM32H7P4 Block Diagram
On the software support side, the company offers the STM32CubeH7P package with HAL2 and low–level drivers, middleware and example projects. Users can use STM32CubeMX2 for peripheral configuration and code generation, STM32CubeIDE for development and debugging and STM32CubeProgrammer for firmware programming. In addition, the company provides the X-CUBE-MCSDK for motor control and the X-CUBE-DPOWER for digital power applications. The company also presented two STM32H7P5 development boards for the STM32H7P family, the NUCLEO-H7P5II Nucleo-144 board with onboard ST-LINK debugging and expansion connectors and the STM32H7P5I-DK Discovery kit with an OLED display, Octo-SPI flash, a MEMS microphone, microSD slot and motor-control expansion connector.
STM32 Nucleo 144 development board with STM32H7P5II MCU
ST states that it is sampling the STM32H7P series MCUs now for OEM customers, with volume production expected in January 2027. The press release says pricing starts out at $4.43 for a 1MB flash device in a LQFP100 package, for 10,000 units. For more details, see the product page and the corresponding blog post.
Images used courtesy of STMicroelectronics
