Skyworks Scales Automotive Audio DSPs from One Core to Three
Pin-compatible Cadence HiFi 5 cores, on-chip SRAM, and a graphical toolchain let one board design stretch from entry-level to premium vehicle sound systems.
Skyworks has introduced the SKY4680x family of automotive audio digital signal processors (DSPs), with a live showing planned at Electronica in Munich. The lineup includes three core counts (one, two, and three), and every device shares the same 88-pin QFN footprint. For OEMs and Tier 1 suppliers, that pin compatibility means a single audio board and software stack can serve an entire range of vehicle trims, swapping the DSP based on how much processing each trim demands.
Cores, Memory, and Control
Every core is a Cadence HiFi 5 clocked at 414.72 MHz. Stack three of them, as the SKY46803 does, and aggregate throughput tops 1.2 GHz, while the SKY46801 and SKY46802 supply one and two cores, respectively. Variants with a C suffix (SKY46801C, SKY46802C, and SKY46803C) add an integrated, customer-programmable Arm Cortex-M3 MCU, letting developers run proprietary features and system-control code on the same die instead of bolting on a separate controller.
Memory stays on-chip, too. An 8 MB shared SRAM with ECC removes the need for external DRAM in supported configurations, which Skyworks says shrinks board area, BOM cost, and power draw while limiting exposure to memory supply swings.
Audio I/O and Software Support
Connectivity runs to nine I²S/TDM inputs and nine outputs. Switch on the optional TDM mode and channel counts climb to 32 in and 32 out, for 64 in total. Integrated asynchronous sample rate converters (ASRCs) reconcile separate audio clock domains, and two SPI/I²C ports, three SPI controllers (one supporting XIP for flash), a UART, and JTAG/SWD cover control and debug. The parts can also boot themselves from flash.
Development centers on SLATE, a graphical environment where engineers build audio chains by dragging prevalidated functions into place. Beyond conventional processing, the platform accommodates customer-written algorithms, Edge AI applications, and third-party audio IP, with an SDK to ease integration.
Inside the 88-pin QFN: HiFi 5 cores, Cortex-M3 MCUs, shared SRAM, and nine I²S/TDM audio ports. Image used courtesy of Skyworks
Packaging, Qualification, and Availability
The package measures 12 mm × 12 mm × 0.85 mm and has a 0.5 mm pad pitch. Devices are AEC-Q100 qualified for ambient temperatures from –40 to 105 °C and carry a Moisture Sensitivity Level 2 (MSL2) rating at 260 °C per JEDEC J-STD-020. Engineering samples and the SKY4680x-AADSP-EVB evaluation board are available now. At Electronica (Hall C4, Booth 440), Skyworks will turn a two-channel source into a multichannel mix and run a Skyworks-developed Edge AI siren detection application on the same silicon.
All told, the SKY4680x family looks like a tidy way to keep one audio architecture across an entire vehicle lineup, from budget trims to flagship cabins. Premium and mainstream amplifiers, head units, and digital cockpit or zonal audio systems are the natural homes, while the programmable cores and Edge AI hooks open doors to EV sound design, road noise cancellation, and hands-free voice enhancement.
