Differential Microphone Pre-Amplifier
https://www.electronics-lab.com/differential-microphone-pre-amplifier/
The project shown here is a microphone preamplifier that provides high quality amplification, optimized for use in computers, media and mobile applications. The pre-amplifier provides a differential input stage, making the device particularly effective when layout constraints force the microphone amplifier to be physically remote from the ECM microphone. This project features adjustable gain using […]
PiCAN3 CAN Bus HAT for Raspberry Pi 4 with 3A Power Supply And Real-Time Clock
https://www.electronics-lab.com/pican3-can-bus-hat-for-raspberry-pi-4-with-3a-power-supply-and-real-time-clock/
Copperhill Technologies announced the release of its PiCAN3 CAN-Bus Board for the Raspberry Pi 4, adding Controller Area Network capabilities plus a real-time clock to the new Raspberry CPU. The PiCAN3 board with SMPS (Switch Mode Power Supply) provides CAN-Bus capabilities for the Raspberry Pi 4. It uses the Microchip MCP2515 CAN controller with MCP2551 […]
Spartan Edge Accelerator Board – Arduino FPGA Shield with ESP32
https://www.electronics-lab.com/spartan-edge-accelerator-board-arduino-fpga-shield-esp32/
Spartan Edge Accelerator Board is a Xilinx Spartan FPGA development board in the Arduino UNO shield form factor. With the onboard ESP32 chip, it can also provide WiFi and Bluetooth functions. Arduino – cheap to buy, easy to learn, simple to use, but can’t deal with complex calculations and large projects. FPGA—flexible and powerful—can easily […]
Three-phase, 1.25-kW, 200-VAC small form factor GaN inverter reference design for integrated drives
https://www.electronics-lab.com/three-phase-1-25-kw-200-vac-small-form-factor-gan-inverter-reference-design-integrated-drives/
This reference design is a three-phase inverter with a continuous power rating of 1.25 kW at 50°C ambient and 550 W at 85°C ambient for driving 200-V AC servo motors. It features 600-V LMG3411R150 Gallium Nitride (GaN) power modules with an integrated FET and gate driver mounted on an 1.95-mm Insulated Metal Substrate (IMS) board […]
Dr.Duino Arduino Starter Kit Review – “The Best Arduino Uno Starter kit Available”
https://www.electronics-lab.com/dr-duino-arduino-starter-kit-review-best-arduino-uno-starter-kit-available/
Definitely, Arduino has made it easy for anyone to learn electronics and programming of modern microcontrollers. Not only that, it had brought out a new era of creative makers, just by the single thought, Arduino makes it possible to bring your ideas to life within a fraction of time without costing you a lot. The […]
Advantech Unveils 1U Desktop System EPC-T2286
https://www.electronics-lab.com/advantech-unveils-1u-desktop-system-epc-t2286/
Advantech, a leading embedded computing solution provider, announced the release of its latest new 1U THIN barebone system with 8th Gen. Intel® Core™ processors up to 65W TDP – EPC-T2286 This system supports Intel® 8th generation Core™ i7/i5/i3 processors which bring enhanced performance over previous generations with up to six CPU cores and Intel’s 9th […]
XCOM – Compact, embedded x86 platform for SDR and other applications
https://www.electronics-lab.com/xcom-compact-embedded-x86-platform-sdr-applications/
Designed to support unattended operation, IP65+, and passive cooling Have you ever tried designing a truly embedded x86-based system? We have, and it was a journey full of unexpected pitfalls. Consider the importance of unattended operation, including resilience in the face of power failures and power voltage fluctuation. Need support for different CPU models? A […]
https://www.electronics-lab.com/project/differential-microphone-pre-amplifier/
  The project shown here is a microphone preamplifier that provides high quality amplification, optimized for use in computers, media and mobile applications. The pre-amplifier provides a differential input stage, making the device particularly effective when layout constraints force the microphone amplifier to be physically remote from the ECM microphone. This project features adjustable gain […]
PC Hardware Monitor with Nokia 5110 Display and Arduino
https://www.electronics-lab.com/project/pc-hardware-monitor-nokia-5110-display-arduino/
Either for benchmarking purposes or as external telemetry to help you stay within the acceptable range for your computer power, super users usually have the desire to have a way of knowing what the performance numbers of your PC are. For today’s tutorial, we will build a PC Hardware monitor which is capable of obtaining […]
Wi-Fi 6 milestone reached
https://www.electronics-lab.com/wi-fi-6-milestone-reached/
Wi-Fi 6, the newest generation of Wi-Fi connectivity, reached a significant milestone a few days ago with official certification. The Wireless Broadband Alliance (WBA) is the not-for-profit industry body for the Wi-Fi ecosystem whose members include BT, AT&T and Google. The organization’s General Manager, Tiago Rodrigues states on this development: “This is the point at […]
