BMI270 – ultra-low power IMU from Bosch Sensortec
https://www.electronics-lab.com/bmi270-ultra-low-power-imu-bosch-sensortec/
The smart Inertial Measurement Unit (IMU) BMI270 scores with increased system battery life and an improved accelerometer. Optimised for wearable and hearable applications, the BMI270 is available from Rutronik UK. The newest member of the BMI260 family of IMUs includes intuitive gesture, context and activity recognition with an integrated plug-and-play step counter. The IMU handles […]
Rigol MSO8000 2GHz 4-Channel Digital Oscilloscope Series
https://www.electronics-lab.com/rigol-mso8000-2ghz-4-channel-digital-oscilloscope-series/
10GSa/sec sampling and 500Mpts memory depth makes these 600MHz/1GHz/2GHz  4 channel oscilloscopes stand out from the crowd. Saelig Company, Inc. has introduced the new Rigol Technologies MSO8000 Series of digital oscilloscopes, which combine best in class sampling (10GSa/sec) and memory depth (500Mpts) with a modern, flexible user interface enabled by Rigol’s new UltraVision II architecture […]
Free Elektor Article: Voltage Tracker for Oscilloscope
https://www.electronics-lab.com/free-elektor-article-voltage-tracker-oscilloscope/
Original publication: Elektor magazine November 2016 Author: Kurt Schuster Free download expires: Friday 23 August, 2019. Suppose you want to measure a slowly-varying voltage from a sensor, or perhaps plot the discharge curve of a battery. Is it really necessary to sit there and note down a reading from the multimeter every so many seconds […]
High Thermal Resolution, High Frame Rate, Low Cost Thermal Inspection Camera
https://www.electronics-lab.com/high-thermal-resolution-high-frame-rate-low-cost-thermal-inspection-camera/
The Fotric 326 provides high quality radiometric images full of detailed thermal information in a handheld pistol-grip camera for investigative analysis Saelig Company, Inc. (www.saelig.com) has introduced the FOTRIC 326 Thermal Imaging Camera – a rugged, durable, accurate, and portable handheld heat investigation device, designed for a wide range of equipment and infrastructure thermal diagnostic […]
Take Control of Your Project with COM-CFHB6
https://www.electronics-lab.com/take-control-project-com-cfhb6/
AAEON, an industry leader in embedded computing, announces the COM-CFHB6 Computer-on-Module. Featuring the 8th and 9th Generation Intel Core Processors, it is built to bring flexible computing to any embedded project. The COM-CFHB6 is built to the COM Express Type 6 form factor. It features a wide range of processors from the Intel Celeron to […]
SEGGER Embedded Studio adds support for 3rd party debug probes via GDB protocol
https://www.electronics-lab.com/segger-embedded-studio-adds-support-3rd-party-debug-probes-via-gdb-protocol/
SEGGER Embedded Studio V4.20 adds fully configurable support for debug probes using the GDB protocol. The new version can now be used with any debug probe that comes with a GDB Server. This new feature is included in all editions: ARM, Cortex-M, and RISC-V, on Windows, macOS, and Linux 32- and 64-bit platforms. Embedded Studio […]
MOSFET Amplifier
https://www.electronics-lab.com/article/mosfet-amplifier/
Introduction to the MOSFET We have already seen in detail that a signal amplifier can be made with a Bipolar Junction Transistor (BJT). There are however other types of transistors that can be used to build an amplifier architecture and in this tutorial, we will focus on one of them : the MOSFET (Metal Oxide […]
Axiomtek’s MANO521 – Intel® Coffee Lake-Based Thin Mini-ITX Motherboard
https://www.electronics-lab.com/axiomteks-mano521-intel-coffee-lake-based-thin-mini-itx-motherboard/
Axiomtek – a world-renowned leader relentlessly devoted in the research, development and manufacture of series of innovative and reliable industrial computer products of high efficiency – is pleased to announce the MANO521, a thin mini-ITX motherboard powered by the LGA1151 socket 8th generation Intel® Core™ i7/i5/i3 (code name: Coffee Lake) with Intel® H310 chipset or […]
LED gravity balance simulates a moving particle
https://www.electronics-lab.com/led-gravity-balance-simulates-moving-particle/
This is a nice project by Roel Arits. The project appeared on www.elektormagazine.com and you can find the source files there. This project has no practical use at all, but was initiated as an exercise in implementing physics formulas related to gravity in C-code on an Arduino. To make things visible, a neopixel LED-strip with […]
3D memory die boasts 100+ layer design
https://www.electronics-lab.com/3d-memory-die-boasts-100-layer-design/
Samsung Electronics announced it has begun mass producing 250-gigabyte (GB) SATA solid state drive (SSD) that integrates the company’s sixth-generation (1xx-layer) 256-gigabit (Gb) three-bit V-NAND for global PC OEMs. by Julien Happich @ eenewseurope.com Utilizing Samsung’s unique ‘channel hole etching’ technology, the new V-NAND adds around 40-percent more cells to the previous 9x-layer single-stack structure. […]
