1.14″ 135×240 IPS TFT Display Module
https://www.electronics-lab.com/1-14-135x240-ips-tft-display-module/
DM-TFT114-397 is a 1.14″ 135×240 IPS TFT Display Module with SPI interface. Main features 1.14″ IPS Screen 135 x 240 pixel Interface: 4-wire SPI Supply Voltage: 3.3V power Drive IC: ST7789V Display colors: full colors Operation Temperature: -20℃~70℃ You can purchase the display from www.displaymodule.com for 8.99 USD.
6.5 Trinocular Microscope with 5MP Hybrid HDMI/USB
https://www.electronics-lab.com/6-5-trinocular-microscope-5mp-hybrid-hdmi-usb/
12″ Integrated Heads Up LCD – Ball Bearing Base – ESD Safe ProZoom® 6.5 “Heads Up” Video Trinocular Microscope featuring Super-Wide (28mm) 10X Eyepieces. Standard Magnification Range of 5 – 65x (up to 390X with options). 0.3x CCD Camera Adapter. New 5MP Digital Camera with EXCLUSIVE 12″ Integrated Retina screen with image capture, on screen […]
Variscite announced the launch of VAR-SOM-6UL based on the i.MX 6UltraLite processor
https://www.electronics-lab.com/variscite-announced-launch-var-som-6ul-based-mx-6ultralite-processor/
Variscite announced the launch of the VAR-SOM-6UL System on Module. The VAR-SOM-6UL powered by NXP’s i.MX 6UltraLite / 6ULL / 6ULZ ARM Cortex-A7 processor with up to 900MHz CPU Clock. The new SoM is based on Variscite’s popular DART-6UL platform while integrating additional LVDS bridge option, all packed in SO-DIMM200 form factor to fit the […]
e-con Systems and Variscite LTD collaborate to launch an Ultra-HD MIPI Camera for NXP’s i.MX8 family of Processors
https://www.electronics-lab.com/e-con-systems-variscite-ltd-collaborate-launch-ultra-hd-mipi-camera-nxps-mx8-family-processors/
Following the great demand for a high-resolution camera for i.MX8 processors, e-con Systems has launched a 4-lane MIPI CSI-2 13MP Autofocus camera integrated with Variscite’s i.MX 8 System-on-Module (SoM) platforms. The initial release is compatible with Variscite’s DART-MX8M SoM based on NXP’s iMX8M processor. However, the company has already announced its intentions to expand the […]
UltraMiner FPGA – Affordable 16 nm Xilinx FPGA dev board for crypto mining
https://www.electronics-lab.com/ultraminer-fpga-affordable-16-nm-xilinx-fpga-dev-board-crypto-mining/
UltraMiner FPGA is an Affordable 16 nm Xilinx FPGA dev board for crypto mining and other high performance applications. Mining cryptocurrency can be fun and rewarding, especially if you’re able to set up a “mining rig” at home. For this to be practical, however, you will need a rig that is: Affordable so you can […]
InfraRed Robot Controller Shield For Arduino Nano
https://www.electronics-lab.com/project/infrared-robot-controller-shield-for-arduino-nano/
This compact Infrared robot controller is based on Arduino Nano and L298 H-Bridge. The Nano shield can be used in various DC Motor driver applications using infra-red remote control or speed controller using trimmer potentiometer and direction control with help of slide switch.   The board can drive two small size DC-Motors with current rating up […]
Common Base Amplifier
https://www.electronics-lab.com/article/common-base-amplifier/
Presenting the Common Base Amplifier In this article, we present the last topology of amplifiers for bipolar transistors known as the Common Base Amplifier (CBA). In Figure 1 below, the electric diagram of a CBA is presented, no particular bias circuit or decoupling capacitors are shown here. Some specifications need to be highlighted for CBAs […]
Common Collector Amplifier
https://www.electronics-lab.com/article/common-collector-amplifier/
Presenting the Common Collector Amplifier This article deals with another type of bipolar transistor architecture used to amplify signals that is commonly known as Common Collector Amplifier (CCA). The CCA can also sometimes be called emitter-follower amplifier and we will understand why later in this article. The first figure below is a simplified electric diagram […]
Nokia 5110 LCD based Arduino Datalogger with Menu
https://www.electronics-lab.com/project/nokia-5110-lcd-based-arduino-datalogger-multiple-menu-display/
Over time, we have built several Arduino based weather stations, real-time clocks, dataloggers and a dozen of projects based on Nokia 5110 LCD display. For today’s tutorial, we will merge all that we have learned from each of those tutorials and we will build a datalogger with a display that allows you to select different […]
Somu – tiny FIDO2 security key
https://www.electronics-lab.com/somu-tiny-fido2-security-key/
A tiny FIDO2 security key for two-factor authentication and passwordless login Somu is a tiny FIDO2 security key, that you can use on your Google, Twitter, Github account for two-factor authentication, or on your Microsoft account for passwordless login. Somu fits in your USB port, so you’ll never forget your key again. Somu is the […]
