Somu – tiny FIDO2 security key
https://www.electronics-lab.com/somu-tiny-fido2-security-key/
A tiny FIDO2 security key for two-factor authentication and passwordless login Somu is a tiny FIDO2 security key, that you can use on your Google, Twitter, Github account for two-factor authentication, or on your Microsoft account for passwordless login. Somu fits in your USB port, so you’ll never forget your key again. Somu is the […]
Tiny i.MX8M Mini module plugs into carrier via M.2
https://www.electronics-lab.com/tiny-mx8m-mini-module-plugs-carrier-via-m-2/
WB15 NXP i.MX 8M Mini SoM is Wireless System-On-Module. WB15 – the latest wireless System-on-Module powered by NXP®’s i.MX8M Mini application processor. NXP i.MX 8M Mini applications processor blends advanced processing capabilities and deliver low-power and high-performance solutions for embedded consumer applications. WB15 SoM, InnoComm advanced NXP® i.MX 8M Mini audio processing SoM is designed […]
How to Use I2C EEPROM with Arduino
https://www.electronics-lab.com/how-to-use-i2c-eeprom-with-arduino/
Expand your board’s storage with an I2C-enabled EEPROM chip. EEPROM stands for Electronically Erasable Programmable Read-Only Memory. It allows for values to be written and stored for long periods of time while using very little power. Most microcontrollers even have EEPROM directly in their circuitry, such as the ATmega328P (Arduino Uno chip), which has 1KB […]
Tiniest USB development board with Micronucleus
https://www.electronics-lab.com/tiniest-usb-development-board-micronucleus/
Development board for the ATtiny84a with USB connector. Pre-loaded with the Micronucleus bootloader compatible with Arduino. DIP version with USB connector of the ATtiny84a. The board can be placed in the middle of the breadboard. Sketches can be uploaded from Arduino using the Micronucleus bootloader. There is an indicator LED to determine if the board […]
Samsung reveals 108Mp Image Sensor for Smartphones
https://www.electronics-lab.com/samsung-reveals-108mp-image-sensor-smartphones/
Samsung Electronics introduced the 108 megapixel (Mp) Samsung ISOCELL Bright HMX, the first mobile image sensor in the industry to go beyond 100 million pixels. With the latest addition, Samsung will expand its 0.8μm image sensor offerings from its recently announced ultra-high 64Mp to 108Mp, a resolution equivalent to that of a high-end DSLR camera. […]
PSRR of low dropout voltage regulators
https://www.electronics-lab.com/psrr-low-dropout-voltage-regulators/
Here’s an app note about PSRR of LDO from Microchip. The Power Supply Rejection Ratio is the ability of a device, such as a Low Dropout Voltage regulator, to reject the various perturbations that can be found in its input supply rail by providing a greatly attenuated signal at the output. Generally, the main source […]
Bridegtek’s PanL Technology Set to Redefine How We Interact with Our Living & Working Spaces
https://www.electronics-lab.com/bridegteks-panl-technology-set-redefine-interact-living-working-spaces/
13th August 2019 – Bridgetek is taking the ground-breaking PanL smart automation platform to the next key stage in its development, ready for widespread deployment to begin. Those attending the Smart Cities & Buildings Asia event this year (Singapore, 4th-6th September) will be able to see real-word examples of how this highly versatile technology can […]
AI@Edge Compact Fanless Embedded Box PC with NVIDIA Jetson TX2 and 4 PoE LAN
https://www.electronics-lab.com/aiedge-compact-fanless-embedded-box-pc-nvidia-jetson-tx2-4-poe-lan/
AAEON, an industry leader in AI solutions, announces the BOXER-8170AI, our newest embedded AI@Edge computing solution featuring the NVIDIA Jetson TX2. Equipped with four PoE LAN ports and four USB 3.0 ports, the BOXER-8170AI provides stability and flexibility for AI edge networks. The BOXER-8170AI features the powerful NVIDIA Jetson TX2 6-core processor, designed by pairing […]
Axiomtek’s New 10.4″ Rugged and Versatile Vehicle-Mounted Touch Panel Computer – GOT610-837
https://www.electronics-lab.com/axiomteks-new-10-4-rugged-versatile-vehicle-mounted-touch-panel-computer-got610-837-2/
Axiomtek – a world-renowned leader relentlessly devoted in the research, development and manufacture of series of innovative and reliable industrial computer products of high efficiency – is pleased to introduce the GOT610-837, an ultra-rugged 10.4″ vehicle-mounted touch panel computer for logistics and manufacturing applications. The feature-rich vehicle-mounted terminal is powered by the quad-core Intel® Atom® […]
32 band audio visualizer using an ATTiny85
https://www.electronics-lab.com/32-band-audio-visualizer-using-attiny85/
“attiny85-spectrum” is a 32 band audio visualizer using an ATTiny85 and an SSD1306 OLED display. Built in Arduino. The goal of this project is to get smooth, appealing music visualization on the ATTiny85, optimizing around its limited speed and resources (RAM and program memory). Its on ongoing personal project right now which I mean to […]
