ST releases ROM-Based GNSS module
https://www.electronics-lab.com/st-releases-rom-based-gnss-module/
Designed for mass-market tracking and navigation applications, the Teseo-LIV3R ROM-based module, has full GNSS algorithm capability for cost-conscious tracking and navigation devices, says ST Microelectronics. The GNSS module provides odometer functionality with three trip counters and reached-distance alert, along with geo-fencing capabilities with up to eight configurable circles and crossing-circles alarm. Support for real-time assisted […]
NANO²® High-Current Subminiature Fuse – 456SD Series
https://www.electronics-lab.com/nano%c2%b2-high-current-subminiature-fuse-456sd-series/
Littelfuse’s small sized, surface-mountable high-current fuse provides surge current protection. Littelfuse’s 456SD series NANO² fuse is a small sized, surface-mountable high-current fuse which provides over current and excessive surge current protection for applications operating at high current in a limited space. Such applications are mostly served today through a single large-sized high-current industrial type fuse […]
VEML6035 Digital Light Sensor operates via simple I²C
https://www.electronics-lab.com/veml6035-digital-light-sensor-operates-via-simple-i%c2%b2c/
Vishay’s low-power, high-sensitivity, ambient light sensor operates via simple I²C command Vishay’s VEML6035 is a 16-bit, low-power, high-sensitivity CMOS ambient light sensor operated via a simple I²C command. The sensor offers an active interruption feature that is triggered outside of the threshold window settings, thereby eliminating loading on the host. The active average power consumption […]
Perf-V FPGA Based RISC-V Development Board
https://www.electronics-lab.com/perf-v-fpga-based-risc-v-development-board/
The Perf-V is an FPGA based development board designed for RISC-V opensource community by PerfXLab. It incorporates various peripheral chips and offers many interfaces. Perf-V has great flexibility and transplant multiple architectures. Some RISC-V development boards with silicon featuring RISC-V instruction set already exist, such as SiFive’s HiFive1 or Kendry KD233 board. One good thing […]
Programmable USB Hub has I2C, GPIO and SPI
https://www.electronics-lab.com/programmable-usb-hub-i2c-gpio-spi/
A USB hub that’s also a dev board and an I2C, GPIO, and SPI bridge In addition to being a 4-port USB 2 High-Speed hub, this Programmable USB hub is also: A CircuitPython based development board. A bridge between your computer and I2C (via Sparkfun Qwiic connectors), GPIO, and SPI (via its mikroBUS header). A […]
LED Lighting Effects Generator using PIC16F886
https://www.electronics-lab.com/led-lighting-effects-generator-using-pic16f886/
This project generates 8 different LED-lighting patterns (Visual Effects) and is based on PIC16F886. The project demonstrates different chasing effects being generated using 20 SMD LEDs and speed of LED-lighting moving is adjustable with the help of the on board trimmer potentiometer. 8 patters can be set using 3 on board PCB jumpers. Circuit consists […]
https://www.electronics-lab.com/project/led-lighting-effects-generator-using-pic16f886/
Commell LE-37M SBC Taps 8th Gen “Coffee Lake” clocked up to 4.3Ghz
https://www.electronics-lab.com/commell-le-37m-sbc-taps-8th-gen-coffee-lake-clocked-4-3ghz/
Commell has launched a 3.5-inch “LE-37M” SBC that taps Intel’s 8th Gen H-series CPUs, and features triple displays, 4x USB 3.1, 2x SATA III, 2x GbE, and mini-PCIe and M.2 expansion. Commell has released a number of Intel’s 8th Gen “Coffee Lake” products and they launched the LV-67X industrial Mini-ITX board last August and followed […]
Infineon’s Solutions for Pumps and Fans
https://www.electronics-lab.com/infineons-solutions-pumps-fans/
Fans and pumps can be found in various applications including home appliances and industrial systems. Driven by more stringent regulations and growing awareness around energy efficiency, this segment is increasingly being shaped by rising demand for inverterization, especially in pumps and fans for low-power drives. Take a look at Infineon’s broad portfolio of solutions with […]
Rigol 1000Z Series 50 to 100 MHz Oscilloscopes for Basic Visualization
https://www.electronics-lab.com/rigol-1000z-series-50-100-mhz-oscilloscopes-basic-visualization/
The 1000Z Series is the economic level Digital Oscilloscope platform from Rigol. It offers unprecedented value in customer applications with its innovative technology, industry leading specifications, powerful trigger functions and broad analysis capabilities. The 1000Z Series 4 channel oscilloscopes come in 50, 70, or 100 MHz versions with a 7 inch display and Rigol’s UltraVision […]
