Intel Wi-Fi 6 AX200 Launches With Linux Support
https://www.electronics-lab.com/intel-wi-fi-6-ax200-launches-linux-support/
WiFi 6 (aka 802.11ax) can deliver up to 10 Gbps in theory, and provides better handling of high density scenario in train stations, conferences, etc… We’ve seen it implemented in some routers and smartphones, but most laptops don’t support the new WiFi standard, so in order to solve this little issue, Intel has now launched […]
CM3 PLAYER Carrier Board for Raspberry Pi CM3+ Targets LVDS Displays
https://www.electronics-lab.com/cm3-player-carrier-board-raspberry-pi-cm3-targets-lvds-displays/
LCDIS, a French company specialized in embedded & display solutions, has been working on a carrier board for Raspberry Pi Compute Module 3+ designed to drive displays used in industrial applications such as digital signage and HMI. For that purpose, CM3 PLAYER exposes LVDS, backlight, and MIPI DSI connectors, as well as Ethernet, four USB […]
Top 10 Upcoming Linux Boards to watch in 2019
https://www.electronics-lab.com/top-10-upcoming-linux-boards-watch-2019/
We have seen a series of Linux-based SBCs the last few months, like the next-gen BeagleBone AI, maker boards from Google and Nvidia, to mention just a few. The SBC market is booming right now, infact a recent Global Market Insights report projects that the SBC market will grow from $600 million in 2018 to […]
LMR36015 – 4.2-V to 60-V, 1.5-A ultra-small synchronous step-down converter
https://www.electronics-lab.com/lmr36015-4-2-v-60-v-1-5-ultra-small-synchronous-step-converter/
The LMR36015 regulator is an easy-to-use, synchronous, step-down DC/DC converter. With integrated high-side and low-side power MOSFETs, up to 1.5 A of output current is delivered over a wide input voltage range of 4.2 V to 60 V. Tolerance goes up to 66 V. The transient tolerance reduces the necessary design effort to protect against […]
HS101: A high quality, and Cheap DIY Oscilloscope
https://www.electronics-lab.com/hs101-high-quality-cheap-diy-oscilloscope/
The Oscilloscope is a test instrument used for the visualization and observation of varying signal voltages, usually as a two-dimensional plot with one or more signals plotted against time. They are used in the design and debugging of electronic devices to view and compare waveforms, determine voltage levels, frequency, noise and other parameters of signals […]
https://www.electronics-lab.com/project/hs101-high-quality-cheap-diy-oscilloscope/
One of the most interesting thing about being a maker is you never get tool-stranded, with the right components, makers tend to have the ability to build makeshift tools on the go. Today, we will take a look on how to build a cheap version of one of the most important tools for any electronics […]
Azure Sphere MT3620 Starter Kit for Creating Secured IoT Edge Devices
https://www.electronics-lab.com/azure-sphere-mt3620-starter-kit-creating-secured-iot-edge-devices/
Last year, Microsoft signed with Avnet as a strategic partner for their Azure platform – a platform for robust cloud computing. This partnership is expected to help boost the already fragile IoT market and adds some level of reputation to it considering Avnet is a big name in the electronics industry and Microsoft a top […]
LPS33W – MEMS pressure sensor withstands harsh environment
https://www.electronics-lab.com/lps33w-mems-pressure-sensor-withstands-harsh-environment/
MEMS pressure sensor: 260-1260 hPa absolute digital output barometer with potted gel package. STMicroelectronics LPS33W MEMS Pressure Sensor is ultra compact and functions as a digital output barometer. The LPS33W combines a sensing element and an IC interface which communicates through I2C or SPI from the sensing element to the application. Detecting absolute pressure, the […]
15% Off – Exclusive Farnell Offer
https://www.electronics-lab.com/15-off-exclusive-farnell-offer/
Get 15% discount off Farnell products until the 30th April when buying via OEMsecrets.com You’ll just need to select the correct code based on your location and apply at checkout with Farnell, when clicking to “Buy Now” through our site. Click the View Offer button below for more information and to claim your discount code. [VIEW OFFER] See the most popular codes below. Click […]
8 RGB LED Driver Shield for Arduino Nano with Optical Defuse Sensor
https://www.electronics-lab.com/8-rgb-led-driver-shield-arduino-nano-optical-defuse-sensor/
The board consists of 8 x RGB LEDs 1W, BJT transistors on each LED, series resistor across the LED for current limiting, a hole to mount 18mm optical sensor which may be a defuse sensor for object detection with Arduino nano. The board can be programed to create multiple RGB LED related applications, like interactive […]
